View Full Version : Cell Voltage After Charging....
LiPo Power
06-21-2010, 05:47 PM
May I ask someone to check each cell voltage of 4S LiPo battery after charging please?
Thanks
Robert
06-21-2010, 05:50 PM
Each cell should read 4.2 volts when fully charged - so that's 16.8 volts for the pack.
BondoBrushless
06-21-2010, 06:00 PM
+1
Weither it's a 2s or a 10s voltage should peek at 4.20v per cell, 4.18,4.19 is exceptable also.
LiPo Power
Ok I just checked my 2 4S new LiPos and I have:
1=4.14
2=4.17
3=4.19
4=4.18
Is that good or my cells are way out of balance for me to swich to panic mode?
Robert
photohoward1
06-21-2010, 06:03 PM
1=4.14
2=4.17
3=4.19
4=4.18
Robert
Do you balance when you charge. Don't panic!
LiPo Power
06-21-2010, 06:04 PM
Could you please tell me what voltage would be not acceptable or alarming when it comes to out of balance?
Thanks
Robert
+1
LiPo Power
06-21-2010, 06:05 PM
Since I do not balance when discharging in my boats I only balance sometimes....
Is that ok?
BondoBrushless
06-21-2010, 08:20 PM
Agreed, no need to panic. They can be brought back to where they need to be.
What kind of charger do you have ?
Is it capable of discharge balance also ?
If so, just cycle it a couple times and it should bring everything together.
#1 - Always balance when chargeing !!
LiPo Power
06-21-2010, 08:26 PM
What kind of charger do you have ? Turnigy
Is it capable of discharge balance also ? YES
If so, just cycle it a couple times and it should bring everything together. Roger That, thank You
#1 - Always balance when chargeing !! Roger That, thank You
dana
06-21-2010, 08:49 PM
I ALWAYS balance charge... i have mistakingly done a regular charge and my cell voltages are like 4.12 etc..... balance charging always keeps them at 4.20v.
photohoward1
06-21-2010, 10:28 PM
Did the Voltage come up Different after a balance charge?
HT
LiPo Power
06-21-2010, 10:34 PM
Not sure yet as my LiPos are charged and I need to use them and charge again. I will balance charge them this time and check voltage then....
Thanks
Robert
HT
Doby
06-21-2010, 11:26 PM
1=4.14
2=4.17
3=4.19
4=4.18
Robert
Your cell voltages are fine as listed. You are only talking several 100ths of a volt differences and measurment in-accuracies of meters, chargers etc can play a role in the reading differences.
kookie_guy
06-22-2010, 12:09 AM
I may be asking a stupid question, but don't all lipo chargers just automatically always balance charge? I use a hyperion DUO
Chilli
06-22-2010, 12:45 AM
Nope. Not all Lipo chargers have internal balancers. The Hyperion 1210i charger for example requires the LBA-10 external balancer to balance packs.
kookie_guy
06-22-2010, 12:35 PM
Gotcha. Thought it was standard practice to include balancing. But like I said, only thing I've ever used is my duo
