View Full Version : Help on battery choice for newby
Davidg
06-17-2010, 08:51 PM
Hi i have 29" delta copy with a kb45 08xl 1600kv and a hydra hv 120 esc runing a prop that has 1626 on it is 42mm 2 balde what batteries should i be using and does the rest of the set up look ok.
Davidg
06-17-2010, 11:16 PM
can anyone help
BHChieftain
Hi,
With your low KV motor, you actually have 2 choices:
1) Run 4S1P with a large prop
2) Run 6S1P with a small prop
I like lower RPMs with a larger prop as I suspect parts will last longer.... but it will run slower.
My Syncron config is simliar to what you have above, except that I have a 240A ESC. I think you'll be fine with 4S on the 120, but maybe not with 6S...
Chief
Davidg
06-17-2010, 11:39 PM
thanks i have a hydra hv 120 esc that can take 50 volts what mah anc c rating should i be using
LiPo Power
06-18-2010, 12:56 AM
Higher MAH will give you longer run....
C rating from 25 = ok power kick
C rating up to 40 or higher = wicked power kick
You can use any available to you. Higher the C is, better the discharge will be, its like better octane fuel for your car....
I have DF-29 and using 2 x 2S lipo batteries, total of 14.8V, some are 20-25C, some are 30-40C....
Cheers
Robert
mappo
06-18-2010, 12:58 AM
Hey depending on the run time you want! i will use a 5000mah @20c the least
Diesel6401
06-18-2010, 01:14 AM
Get 2 of these each. Open up your options to find the best set-up. That way you can run 4s, 5s or 6s till you find your happy place :smile:
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=10305
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=10306
Dangerous_Toys
06-18-2010, 01:16 AM
Seems to be a broken link Diesel
Diesel6401
06-18-2010, 01:18 AM
Yea i hit the wrong button and ran two links together :doh: try again buddy. I think i fixed it.
Dangerous_Toys
06-18-2010, 01:32 AM
:rockon2::thumbup1:
Davidg
06-18-2010, 07:35 PM
thanks for the help
Make-a-Wake
06-18-2010, 10:53 PM
Your ESC may go poof...............the 1600kv KBxl pulls amps like you cant imagine. I've personally confirmed this...............twice.............:crying:
Davidg
06-18-2010, 11:03 PM
hi make a wake thanks what sort of amps does the kb45 xl pull sould my batteries have higher or lower amp than my esc is rated as i am now confused
Make-a-Wake
06-18-2010, 11:13 PM
I'd run 25c / 5000 mah minimum, you may get away with the 120a esc, but it'll be close.............prop it conservatively and it may work.
Davidg
06-18-2010, 11:16 PM
thanks for the info what sort of amps does the kb45xl pull
would you be so kind to help me with a few questions below as the more reading i'm doing the more confused i getting
1. does the battery amps need to be higher or lower then you esc is rated.
2. with this setup am i better to run higher volt or amps
i currently have 2 x 4s 35c 3000 mah and 2 x 4s 4000mah 15c batteries
alos would it be better to run in paralell which doubles your amps and run time or series which will double my volts as far as i understand
any help would be appricated
mschaffer66
06-18-2010, 11:34 PM
I just ordered a pair of the new EX Hyperions at our shop. 3S, 5000MAH, 45C continuous...bling bling :)
