View Full Version : Ammo and Turnigy!!!
xxxrems38xxx
06-17-2010, 07:51 AM
hi boaters!!
Notice to everyone, the marine Turnigy 180A esc is not compatible with the motor 2300kv ammo there is a cogging effect and a sizzling engine at low rate! If someone has had the same config with the same problems it'll be nice to give me advice! thanks to all :o
LiPo Power
06-17-2010, 08:01 AM
What boat is it in?
Is it Formula fastech? If yes, did you try your ESC with the stock motor?
Robert
xxxrems38xxx
06-17-2010, 08:29 AM
yes with the stock motor all is alright nice accelerations timing at 11.25° and the esc and motor is barely warm
LiPo Power
06-17-2010, 09:24 AM
Stock motor is one of the best motors out there for your boat. It has power and you can even up-prop your boat a little. Make sure to check temps as you do.
Are you running stock prop or X642? This upgrade prop is all you need to get more speed and fresh set of LiPos....
Robert
ED66677
06-17-2010, 02:28 PM
anybody has ever tried this combo?
The ammo is a 6 pole, is the pro boat a 4 pole?
I know somebody posted a timing guide according to the number of poles a motor has...
Jon
xxxrems38xxx
06-17-2010, 04:40 PM
Turnigy marine 180A is it compatible with 6 poles motors?
http://forums.offshoreelectrics.com/showthread.php?t=15348&highlight=ESC+timing
6S HYDRO
06-17-2010, 08:36 PM
the ammo 2300 is not a 6pole motor it is a 2 pole. the ul-1 motor is the 6pole one.
6S HYDRO
06-17-2010, 08:37 PM
ul-1 esc runs this motor flawlessly and in the post above it states that it runs 10d timing. try the turnigy on 10 degrees
xxxrems38xxx
06-18-2010, 01:31 AM
the timing of my turnigy is 11.25 ° and then moved to 15 ° and I have already try all the settings and nothing to do! which is strange because with my original motor and another motor in hobbyking everything works without worries! Do you think it would come from the radio or receiver?
6S HYDRO
06-18-2010, 01:35 AM
maybe you got a bad motor, or the turnigy just doesnt like 2 pole motors
6S HYDRO
06-18-2010, 01:36 AM
have you tryed the motor on the stock esc? they run great on sv-27 or ul-1 esc's
xxxrems38xxx
06-18-2010, 02:20 AM
I'm going to buy a 60A aquacraft be sure that it works? is there a programming card for this esc? and up to how many lipo cells can support?
BakedMopar
06-18-2010, 04:28 AM
If the speed control operates other motors then you should be looking at the motor for problems. Could be a bad solder joint or just a lemon from the factory.
Brushless01
06-18-2010, 02:58 PM
The ul1 esc is great with the ammo 2300 !! No it comes pre programmed and ready to rock
6S HYDRO
06-18-2010, 04:26 PM
yep just plug and play
xxxrems38xxx
06-18-2010, 04:42 PM
can it operate in 5s?
6S HYDRO
06-18-2010, 04:47 PM
yes but only for A short burst, like a speed run
Brushless01
06-19-2010, 02:06 AM
On 4s with the Ammo motor and ul1 esc its more than enough run 4s it will last longer and be plenty fast enough .
xxxrems38xxx
06-20-2010, 08:10 AM
Thank you all for your help!! My problem is solved, I bought a radio spektrum with a receiver DX3E RM 3000 and the cogging disappeared with some small adjustments that it's on the radio! It must have come from my radio "PROBOAT"!I have set the timing on 3.75 ° because your advice said that for the 2 pole motor timing was between 0 and 5 degrees and everything works fine now! Thank you very much
forescott
06-20-2010, 10:28 AM
Ah, good ol proboat am radio!
