View Full Version : turnigy 180 program card
bustitup
06-16-2010, 04:53 PM
when I first got the card it worked fine
now I get no led lites lighting up
i have the right one its the green one
anyone else experience a bad card
Rumdog
06-16-2010, 04:55 PM
Did you blow the bec? Try disconnecting the red wire and plugging a rx pack into the other spot in the card.
bustitup
06-16-2010, 04:58 PM
I have two brand new esc and have tried every configuration imaginable and no lights
when I first got the card it didnt work at first and suddenly after many tries it lit up
now nothing........ so I'm thing it was intermittent when I got it
anyone got one for sale in the USA?
Rumdog
06-16-2010, 05:00 PM
Pull it apart bustit. Could be as simple as a bad solder joint.
bustitup
06-16-2010, 05:03 PM
I did that and everything was tight tight tight
mschaffer66
06-16-2010, 09:40 PM
Not to hijack...but have you also had problems with not being able to access their "advanced fuctions" on the programmer or not being able to access some of the extra values, like setting 6 for parameter 3?
bustitup
06-19-2010, 06:45 PM
update:
seems soon as I connected the motor to the esc the program box now works
is this normal?...the esc must be connected to the motor for the programmer to work?
sailr
06-19-2010, 07:26 PM
Yes. You have to have everything hooked up. power battery plugged in, throttle lead to the program box and external battery if you're not using the BEC.
