View Full Version : What voltage to charge at???
agressive1
06-15-2010, 10:44 PM
Hey
I have a Swallow EQ charger and i have 22.2v LIPO battery packs to charge although i realised that my charger only goes up to a 19.6v as its maximum Voltage when choosing Lipo mode to charge.
Can i just charge my 22.2v packs on 19.6v?
Also i have a 6.6v LIFE battery do i have to change the voltage to 6.6v as well or can i just keep it at 19.6v
Thanks
Dean
mappo
06-15-2010, 11:07 PM
Hey
Thanks
Dean
Hey guy, your question is too vague! A charger is rated by amperage, and how many cells it will charge. voltage is varied by the charger and so a charger is only good for so many cells. read your chargers manual. if your charger is good for 4 lipos then you will not be able to charge 6 lipo cells. what little i know of the swallow charger, will charge up to 6 lipos at .1- 6 amps so you will be fine!
agressive1
06-16-2010, 04:46 AM
Ok
But when i charge with a LIPO i can choose a different voltage setup on the charger as well as me changing the Mah etc, do i just leave it at 19.6v?
Xfactor
06-17-2010, 11:36 AM
Cant a 4s charger charge 8 s (two 4s packs in parallel)? but it would take longer.
Chilli
06-17-2010, 01:44 PM
I did a little reasearch online and think I found a manual for your charger to try and help answer your question. Is your charger the Swallow EQ ac/dc charger with 50 watt output? Exactly what packs are you trying to charge? One 6s pack, two 4s packs????
agressive1
06-17-2010, 08:52 PM
Hey yes it is that charger
Iam charging a Flightmax 5000mah 22.2v 6s lipo packs, one at a time.
And a LIFEPO4 850mah 6.6v 2s battery.
So what do i set the Voltage at to charge these batterys?
Chilli
06-17-2010, 09:59 PM
Okay I read the manual and I think you may be in the wrong charge mode for your LiPo packs. LiFe charge mode has a max charge voltage of 19.8v max. LiPo charge mode has a charge rate of 22.2v and thats the mode you need for your 6s Lipo packs. The LiFe charge mode also has a 6.6 volt setting so thats what you need for your LiFe pack.
Now the bad news. That charger has only a 50 watt output as does many ac/dc chargers. Expect a charge time over two hours for each 6s/5000 mAh pack.
agressive1
06-19-2010, 12:32 AM
Hey
Yes thats correct, i thought i was rite with what i was doing just wanted to ask first.
Yeah will take a while to charge aww well, will have to be a over night charge.
kookie_guy
06-20-2010, 12:10 AM
Hey
You're gonna leave a 6s lipo to charge overnight unattended? :eek::nono::scared:
agressive1
06-20-2010, 03:03 AM
Will be attended of course :)
