View Full Version : Turnigy/ Hobbywing 180a on 6s2p..anyone doing it?
cybercrxt
06-11-2010, 11:04 AM
Well, I would like to know if anyone is doing the hobbywing 180a ESC on 6s, and what setups, speeds, props, etc. I am thinking about giving it a try with a 1527 1Y 1250kv on 6s2p with the Executone 1/8th scale hull I am building right now. I have the motor and controller already. I have been running the Neu/Castle 2200kv 1515 1Y and hobbywing 180a ESC on 5s1p all day long in my Woodstuff 32" hull doing 65mph in heat trim, so it got me thinking could this controller hold up to a 1527? Any info would be great! Thanks, Mike
hebner
06-11-2010, 11:27 AM
Mike,
Sailr was using the Turnigy 180A probably same as hobbywing in his 36" Sprintcat on 6s2p, motor was a Feigao580L 10L worked ok until his motor burned up. I have a 1527 1Y, 6s2p in my 36" Team Believer Cat using a Hydra 240 LV and have had no problems.
drwayne
06-11-2010, 11:36 AM
on 6S2P you will discover the thermal cutoff does work well. !
180A continuous is a bit ambitious with a small heatsink
I ran 1521/1Y on 6S1P but logged at 170ish it would thermal.
cc/etti/yge or equiv do not.
jm2cw.
Wayne
cybercrxt
06-11-2010, 12:02 PM
What Etti are you saying would do ok?
Sounds like the castle 240lv is tougher than I thought. I run it 5s2p on my 36", 9.5lb woodstuff 36" tunnel, with 1518 1Y Castle/ Neu, doing 68mph in heat trim. I didn't know people ran the LV on 6s! Maybe I should just get another 240lv CC. What speeds are you guys getting from your boats?
hebner
06-11-2010, 12:14 PM
Actually there are two of us using the Hydra 240LV on 6s2p, the other boat is a Sprintcat. Our speeds are 55+ in race water we all use x447/3 blade props.
drwayne
06-11-2010, 12:30 PM
the video says it all.. :) :) :)
80mph = 130+kmh
1521/1Y CC240LV Thunderpower6S5000 40C (http://www.youtube.com/watch?v=QyOL6dmcO8k)
make sure you use a connect resistor before you ZAP the esc.. capacitor failure an issue with cc ..I use 52ohm1/2W to drop initial current before the main batt plug connected.
cybercrxt
06-11-2010, 12:51 PM
Great info and video. Looks like I will give the Hydra 240lv a try on my build! Mike
Rumdog
06-11-2010, 12:54 PM
I wouldn't trust the 240 lv on 6s. Too many horror stories. Why not just get a swordfish 240hv? I ran a 240lv on 5s2p with a 1527 1.5d in a 34" sprintcat. I ran hot on a x455, but never failed. Myself, I wouldnt do 6s on it.
cybercrxt
06-11-2010, 03:01 PM
I had two of the Swordfish 240hv controller, one failed, and the other got so hot I was afraid to use it. I sent them back, but never heard what the problem with them was. I ran them on 5s2p, so I don't know what the deal was. Mike
Make-a-Wake
06-11-2010, 04:34 PM
I run my 1527(1250kv) on 6s with a Turnigy 180a in a 45" mono.........all components are barely warm.......................
drwayne
06-11-2010, 08:09 PM
Mike, a quick ps ..
in Au our ruleset allows only 1P..
that vid was 6S1P ...
The 6S1P allowed 225A cont = 5000W which exceeds your 1527 by 2KW
Peaks of 450 = 10,000W = something's toasting.
and you plan 6S2P .. wow factor 110% !
Rumdog
06-11-2010, 08:49 PM
Wow, this is good to know. What prop, and what speed are you getting?
Make-a-Wake
06-11-2010, 10:08 PM
"Wow, this is good to know. What prop, and what speed are you getting?"
Its a "sport boat", no racing or maxxed out high speed runs, so i am running an X445 and GPS'd it at 36....................It has never been warm to the touch..........I am 100% satisfied with the motor and my setup.:bounce:
Himalaya
06-12-2010, 01:41 AM
I do. my setup:
Delta Force Cyber Storm Hull
HobbyWing Seaking 180A
Medusa 36-80 - 1600KV
LiPo 6S 2P 22.2V 8000mAh total
Prop: Octura X537-3, Prather 220
Speed: 93km/h
After 5 minutes of full throttle (except at corners), nothing is more than slightly warm. Motor about 45°C, ESC...... cold actually, my finger does tell me it's a few degrees higher than ambient, and that's it.
m4a1usr
06-12-2010, 01:23 PM
And from what I remember about the CC240 LV warranty Castle wont replace it on anything over 4S. Unless they have changed their tune in the last year.
John
drwayne
06-12-2010, 09:08 PM
John
Castle do cover buyers with warranty up to 6S.
We've made claims on 6S without problem these past few years
Id be surprised if that were different for ' local ' users.
Swordfish240HV is good,
Buy one here at ose.
Wayne
Alexgar
06-12-2010, 10:15 PM
i run a 220 castle nue os 6s2p and the turnigy 180 is the only setup that doesnt burn up, also using a proboat prop , by the way this is in a pb fasttech
