View Full Version : F1 24" Finally finished.
F1 madness
06-10-2010, 02:45 PM
Well iv finally got the rest of my bits together,and now my F1 24" is finally ready to get wet.
Its running a hobbywing 3600 kv water cooled motor that iv mounted on a modified original dolphin outboard,up graded flexi and ballrace sealed bearings on stub shaft and twin cooling pick ups,hobbywing 60amp esc,futaba 3004 servo for steering with twin cable (push-pull system).Lipos are overlanders 3200 mah,20C 3s 1p,11.1 volt.Iv got 3 props to try 31mm,34mm,38mm.
But will probably just stick to the 31mm.Weather depending will try tomorrow and hopefully get a vid or 2.
http://i577.photobucket.com/albums/ss219/retic79/F1%20boats/DSC00154.jpg
http://i577.photobucket.com/albums/ss219/retic79/F1%20boats/DSC00149.jpg
http://i577.photobucket.com/albums/ss219/retic79/F1%20boats/DSC00151.jpg
http://i577.photobucket.com/albums/ss219/retic79/F1%20boats/DSC00150.jpg
http://i577.photobucket.com/albums/ss219/retic79/F1%20boats/DSC00152.jpg
http://i577.photobucket.com/albums/ss219/retic79/F1%20boats/DSC00153.jpg
Jedi Master
06-10-2010, 03:31 PM
Very tidy....good job!!!
bigpapa
06-10-2010, 05:18 PM
looks awsome great job, cannot wait to see video of the test run
F1 madness
06-11-2010, 04:40 AM
Cheers guys.
the weather looks abit better today,but surposed to be even nicer tomorrow,so should get the chance to give it a run and hopefully do a bit of setting up,as soon as iv got a vid ill post it :thumbup1:
F1 madness
06-11-2010, 06:13 AM
Well heres somthing interesting just weighed the boat out of interest with everything in inc batt,1.2kg cant beleive how light this is.
So will definatly be interesting to see how it goes.
Xfactor
06-11-2010, 10:03 AM
Boy thats nice.
F1 madness
06-11-2010, 11:07 AM
Well took it out and this was the result,heres a link to some vids:
the the 1st 2 are last runs with the 34mm prop and abit of an angle adjustment on the outboard.
http://s577.photobucket.com/albums/ss219/retic79/Boat%20vidz/
Boy was i surprised and hope you are to.
will try and get some better vids tomorrow hopefully.
F1 madness
06-11-2010, 11:08 AM
Boy thats nice.
Cheers bud,took alot of working building this from scratch and was worth it,after watching how it goes.
F1 madness
06-12-2010, 11:34 AM
well heres a run from today,bit dissapointed i could do 1 pass ripping up the canal,then the esc is shutting off and only giving me half the power,think i need a bigger esc.click on pic to view the vid
http://i577.photobucket.com/albums/ss219/retic79/Boat%20vidz/th_MOV00171.jpg (http://s577.photobucket.com/albums/ss219/retic79/Boat%20vidz/?action=view¤t=MOV00171.mp4)
http://i577.photobucket.com/albums/ss219/retic79/Boat%20vidz/th_MOV00166.jpg (http://s577.photobucket.com/albums/ss219/retic79/Boat%20vidz/?action=view¤t=MOV00166.mp4)
thought id try and lower the out-board a little heres the result lol
http://i577.photobucket.com/albums/ss219/retic79/Boat%20vidz/th_MOV00167.jpg (http://s577.photobucket.com/albums/ss219/retic79/Boat%20vidz/?action=view¤t=MOV00167.mp4)
sailr
06-12-2010, 12:28 PM
With a 3600KV motor on 3S I would suggest a 432 prop. Here are some possibilities.
1. Weak battery (even though brand new, it may not be able to sustain high discharge) and is approaching LVC. I have had this happen and puzzled and puzzled only to be solved by a different battery.
2. ESC approaching temp cutoff because of too much prop.
3. Prop too deep in the water, drawing too many amps. Where is your prop shaft located in relation to the bottom of the sponsons?
Other than that, I'm as mystified as you! Hopefully somebody else here can be more helpful. The ride attitude of the boat looks good so I think you have the angle of the motor correct.
F1 madness
06-12-2010, 12:32 PM
Cheers bud iv tried 3 batterys still the same and only running a 31mmd,1.4p prop iv tried raiseing the prop,and is centre line of the prop is just above the bottom of the sponsons and still the same,looks like i need a bigger esc
sailr
06-12-2010, 01:02 PM
You could be right about the bigger esc. I'm surprised it doesn't get really hot though if that is the problem. I would be surprised if that motor/prop is pulling that many amps but it is difficult to know for sure. Maybe it is a faulty ESC as well.
Where do you have the timing set for that motor? I imagine it's just a 2 pole. I wouldn't run it any higher than about 5 degrees advance. You might try that. Might have some bearing on the issue but not sure.
F1 madness
06-12-2010, 01:07 PM
iv not set the timing,iv just plugged it in and set the throttle range,ill find the instructions and have a look to see how i adjust it.
Xfactor
06-13-2010, 08:37 AM
Id step down on the prop 3s on a 3600 kv motor might be getting on the hot side of things . Try a 430 or a 427.
Xfactor
06-13-2010, 08:39 AM
Youd be surprized at the difference a few mm on prop size makes.Try a smaller prop.
F1 madness
06-13-2010, 08:51 AM
alrite bud the motors comes in cold,only the esc is warm (not hot just warm to the touch)
F1 madness
06-13-2010, 08:54 AM
oh i know how much load a prop can put on a motor,iv tried a smaller prop but just getting loads slipage even at low throttle,then it still cutting power
F1 madness
06-14-2010, 11:34 AM
well ordered a bigger ESC just gotta wait for it to turn up up then will go and try it,and hopefully the problem will be cured and can get some more vids:popcorn2:
F1 madness
07-06-2010, 06:48 AM
SORTED new ESC has arrived and installed,just charging batts and im off to do some runs,hopefully problem cured and will get some vids if all goes well.
Cant wait the excitement:banana::banana::thumbup::thumbup:
Rumdog
07-06-2010, 04:11 PM
Any news?
F1 madness
07-06-2010, 04:19 PM
Not good im affraid,major disaster in fact,had to scrap hull,gotta build a new 1.
ah well time for a new build hehe
Rumdog
07-06-2010, 04:27 PM
Whaaaa?! Fire? Crash? Pic please!
F1 madness
07-06-2010, 04:37 PM
Hole in bottom of centre sponson,as i throttle it hit somthing in water (couldnt see it)
the boat flipped,managed to retreive it and there was the hole:
http://i577.photobucket.com/albums/ss219/retic79/F1%20boats/DSC000202.jpg
ozzie-crawl
07-14-2010, 07:46 AM
thats a shame,looks like with a little sorting it would have been a very nice little runner.
with a little patch work you could make a nice shelf queen if you didnt want to run it again.
F1 madness
07-14-2010, 07:50 AM
it is a shame,was running strong awell,but could patch it and make a fibreglass mould of it and try again,maybe even sell few LOL.
But started new build now to replace it.
