View Full Version : New 40mm Water cooled motor mount
FE Wannabe
06-01-2010, 08:53 PM
Steven,
I was wondering if you have any plans to carry the 40mm version of the water cooled motor mount?
This mount should work nicely with Neu 15xx series, the Castle-Neu 15xx series, as well as the new Leopard 40mm motors that have recently hit the scene, as long as the motors are over 55mm long.
(Correction, these mounts will not work with finned Neu or the finned Castle-Neu motors)
PM me if you need the link.
As always, I would dreather send you my money.
Thanks,
Brad
m4a1usr
06-01-2010, 09:04 PM
Nope. Doesnt work with the Castle/Neu or the finned series Neu motors. The clamping section will not open enough to get around the finned section. Already tried it. Dont waste your money unless you want to start cutting away some material from the motor or the clamp. It will work with the Xerun series motors.
Should work for the longer Leopard 40mm series.
John
FighterCat57
06-01-2010, 09:52 PM
John
Explanation in photos:
There isn't enough material in the top hole to line it up by drilling it either.
Brushless55
06-01-2010, 09:54 PM
nice find Brad!
does someone have these now, I may order two of the Leopard motors soon
FighterCat57
06-01-2010, 09:56 PM
nice find Brad!
http://cgi.ebay.com/aluminum-watercool-motor-mount-40mm-diameter-motor-/290427785251?cmd=ViewItem&pt=Radio_Control_Vehicles&hash=item439ed85023
I have one in hand if you need it sooner. NIB.
Brushless55
06-01-2010, 10:23 PM
Sweet, thanks!
hey that links looks like HOTR may be getting these motors to :banana:
FE Wannabe
06-01-2010, 10:55 PM
John
John,
Thanks for the correction, don't want to spread any bad info. I wasn't thinking about the fins not clearing the mount. I will correct my original post later.
Does this mean the mount should work on the smooth can Neu 15xx series motors longer than 55mm as well? I was planning on using this mount with a Leopard 4074 2200kv anyway, so I should be fine.
Thanks,
Brad
FE Wannabe
06-01-2010, 11:31 PM
FighterCat57,
If Brushless55 doesn't want the mount I may be interested in it.
Let me know.
Thanks,
Brad
06-01-2010, 11:38 PM
Steven,
Thanks,
Brad
I have some on order. I should have them in 2-3 weeks along with some 40mm motors.
Brushless55
06-01-2010, 11:44 PM
Steven you da BOMB! :banana:
what versions are you going to get on the 40's
I would like two 2000kvs
FE Wannabe
06-01-2010, 11:58 PM
Steven,
I should've known you already had these in the works.
Thanks for the ETA.
Brad
FighterCat57
06-02-2010, 06:03 AM
Nice! It's a good little mount.
FYI- might be good to have extra stringers available separately, this mount can be used on the really long motors, like the 1527. The second set of stringers can be turned 120 degrees to hold the tail of the longer motors.
I was going to build a new stringer, but this is so solid that it bends the hull if I try to move it;
