View Full Version : Brushless wildcat
minikitty
05-31-2010, 04:23 PM
Bought a mini wildcat about 2 weeks ago, and now i wanna go brushless. What size brushless will i need to go 50mph +? I know its dual motors and it will need two brushless set ups. Also how do you think it will handle at 50mph
forescott
05-31-2010, 04:26 PM
I would like to see a wildcat go 50mph. I think it would probably take flight at about 40! :unsure:
minikitty
05-31-2010, 04:31 PM
well i wanna see it take flight. but being able to go 50mph. What kind of motors do i need
forescott
05-31-2010, 04:41 PM
Something like a pair of feigao 380s in the 4000kv range. Look em up under brushless motors here on the ose site. Good luck with your build!:zip-up:
FighterCat57
05-31-2010, 05:33 PM
I'm already on it. Have a thread going on it and a brushless setup on the way!
minikitty
05-31-2010, 06:50 PM
Just a set of these motors? What esc would i use to power these?
http://www.offshoreelectrics.com/proddetail.php?prod=fei-380-S
minikitty
05-31-2010, 07:44 PM
how about two of these?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXUFF0&P=7
FighterCat57
05-31-2010, 09:36 PM
Check out this thread; http://forums.offshoreelectrics.com/showthread.php?t=14585
And this one: http://forums.offshoreelectrics.com/showthread.php?t=14882
The motors are tiny, but there are two bolt patterns in the mount, less than 380 sized holes.
I'm starting with a 35-40 amp setup and if it's not enough, going up to 60amp. But battery life becomes an issue at that point.
Jeff Wohlt can make specialty couplers for whichever motor setup you choose. www.rcraceboat.com, just email him and ask.
The props are 1/8th.
Make-a-Wake
05-31-2010, 10:12 PM
Those motors would last about 10 seconds at 9000kv.................. As forescott mentioned 3500-4000kv on 2s would work alright. Something along these lines
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=4196&Product_Name=HXT_2445_(370L)_3790kv_Brushless_Inru nner
Fightercat sniffed these out..............whole setup for $40......need two of course.
http://www.hobbyhot.com/swanghobby-marine-3600kv-brushless-motor-flyermate-atlantis-60-c-281-p-1-pr-2307.html
minikitty
06-01-2010, 04:12 PM
Alright. what kind of ESC would I use to power the engines
FighterCat57
06-01-2010, 04:26 PM
HK has a few 35-40 amp esc's. They need to be conformal coated or silicon sealed though. http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=6461&Product_Name=Hobbyking_SS_Series_35-40A_ESC
You can also add a water cooled heat sink instead of the one that comes with it. There's some floating around, ETTI makes them and OSE has them.
Whatever motor you choose, size the ESC above it's max amp rating and you should be OK.
Alexgar
06-01-2010, 04:28 PM
I did a single brushless mini vee 28-47 2700kv 40 amp esc 3s and 4s on stock hardware. Durability becomes an issue quickly with this much power. Also the weight to power ratio get skewed quickly as it is hard to have something so fast and light keep in the water considering at 30 mph a ripple is a titlewave.About 300$ in to it im now looking for a 16-18" fg hull to tranplant my goodies.Probably a bby warzone jr since i have all the hardware from a brushed one i had many years ago
sailr
06-01-2010, 04:50 PM
Everybody always wants to go faster. Remember, there is a point at which the boat becomes uncontrollable! What's the point!!!?
minikitty
06-01-2010, 06:07 PM
This esc you showed me has bad reviews of burning up. also how hard will it be to wire in two motors? Also what kind speed will i see from this set up you have shown me?
minikitty
06-01-2010, 07:00 PM
also i'm probably not going to be running a lipo. just a custom built nimh battery pack
minikitty
06-01-2010, 07:13 PM
What about props?
FighterCat57
06-01-2010, 07:32 PM
Aw dammit. Well... guess I'm not out that much munny... Shows me for not reading the reviews! (fortuantely I'm running it with much lower draw motors, so it might work)
minikitty
06-01-2010, 07:33 PM
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9484&Product_Name=Mystery_20A_Brushless_Speed_Controlle r_(Blue_Series)
Will two of these work with these motors?
Alexgar
06-01-2010, 07:37 PM
this is what i run in my mini pricey but i prefer to be over rated than purchase twice
http://www.horizonhobby.com/Products/Default.aspx?ProdID=EFLA1040
Alexgar
06-01-2010, 07:38 PM
maybe even this they are pretty small
http://www.horizonhobby.com/Products/Default.aspx?ProdID=EFLA1060
Make-a-Wake
06-01-2010, 08:27 PM
No, not enough amp capacity.
FighterCat57
06-01-2010, 08:44 PM
This might work, but is pushing it; http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9483&Product_Name=Mystery_30A_BEC_Brushless_Speed_Contr oller_(Blue_Series)
I'll let you know how the Hobbyking works out on 2s.
Mixed reviews, but price is right on this guy;
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=6459&Product_Name=Hobbyking_SS_Series_40-50A_ESC
:Peace_Sign:
6S HYDRO
06-01-2010, 08:47 PM
if you wont be using lipos you wont be getting even close to the speeds mentioned probably not even 30
minikitty
06-01-2010, 08:59 PM
What about if i ran 11.1v? Or is lipo the only way to go with the brushless to get highspeeds out of it.
Make-a-Wake
06-01-2010, 09:14 PM
Since you stated you would be running nimh, 11.1 or so would be 9 nimh cells............lots of weight!:crying:
Alexgar
06-01-2010, 09:46 PM
and low discharge rate out of nimh
FighterCat57
06-01-2010, 09:59 PM
I plan on using two of these in parallel.
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=6540
Make-a-Wake
06-01-2010, 10:39 PM
Great choice..............88 cont. amps!:thumbup:
Alexgar
06-01-2010, 10:49 PM
this is the biggest i could jamb in the mini vee
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=9272
FighterCat57
06-06-2010, 06:47 PM
Yep, have to use it on 2s if the motor is above 2000kv. 2s/2900kv should be good to go. There's a note on the specs.
It will be here tomorrow, so should have an update within the week. =) :rockon2:
