View Full Version : Castle/Neu 1518
BakedMopar
05-30-2010, 11:43 PM
If anybody can help me, I need the measurement from the end of the can to the bottom of the wire harness.
Thanks
Heath M
05-31-2010, 02:36 AM
if you mean the casing at the back that houses the wires its 11mm
Heath
BakedMopar
05-31-2010, 02:46 AM
Well technically the front (end where you mount) to the Wire housing. But I'm guessing if that housing is 11mm and total lenght is 83. The measurement should be somewhere in the 72mm range?
Just trying to figure out if the wires will clear the rear mount being that it comes out the side and not the end.
Heath M
05-31-2010, 02:53 AM
yeah it's 73 mm tight from the back of the motor to the where the wires exit the motor
Heath
BakedMopar
05-31-2010, 02:54 AM
Thank you very much!
