View Full Version : New ESC For Fastech
carcode123
05-28-2010, 08:09 PM
My fastechs esc cant go slow. It wil not go slow enough to dock.
I was wondering if there is a more responsive esc i was thinking of the super vee 27 esc, what do you think
Diesel6401
05-28-2010, 09:36 PM
Are you sure you have a esc issue? What troubleshooting have you done? Are you using the stock radio? I would change out the radio system first imo (especially if you have another laying around) before I went to the esc.
carcode123
05-28-2010, 09:39 PM
Im using a DX3s with a mr3000 receiver
I tried give it throttle until the motor spins the prop at the lowest rpm and the its goes to fast.
Diesel6401
05-28-2010, 09:41 PM
O nice radio, just bought one myself haven't used it yet though. Did it do the same with the stock radio? I'm thinking throttle calibration issue that's why I keep asking about your radio system.
carcode123
05-28-2010, 09:42 PM
It did the same thing with both radios, but maybe i should recalibrate the esc.
Diesel6401
05-28-2010, 09:49 PM
I would start their before shelling out money on a esc. To answer your orignal question a sv esc would technically work, but when buying a new esc I like ones with programable features. The sv esc is not programable. But for your reference here's some esc's that would work: I think the hobbywing seaking 60amp would work the best JMO.
http://www.kintecracing.com/Electrical.html (all you need is about a 60amp esc)
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=7360&Product_Name=Turnigy_Marine_60A_Brushless_Boat_ESC
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=10627&Product_Name=Turnigy_AquaStar_90A_Water_Cooled_ESC
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=10626&Product_Name=Turnigy_AquaStar_120A_Water_Cooled_ES C
BHChieftain
05-28-2010, 10:23 PM
When you first power up the esc (with the radio on first) leave the throttle in neutral. You should hear 1 beep. Then apply full throttle, the esc should beep again, then you should be good to go.
Chief
Diesel6401
05-29-2010, 12:31 AM
Do you have the programming card? Adjusting the esc's brake setting and possible even throttle curve setting may help with this. I don't own the boat or any proboat product for that matter (until the tunnel comes out :rockon2:) so I'm just throwing out some ideas.
BHChieftain
05-29-2010, 12:43 AM
I bet it is just improper throttle calibration-- I had this same problem until I figured out the calibration sequence
Chief
carcode123
05-29-2010, 12:10 PM
I looked in the manual and the was nothing about recalibrating the esc.
