View Full Version : Feigao 540 8xl and Hifei swordfish 120 a good como?
Jabbo
05-26-2010, 03:01 PM
I am looking to up grade my fastec would a feigao 540 8xl and a hifei swordfish 120 make a good set up to run 4s and sometime 6s on. Some day I would like to put it in a Challenger 31". Would this work?
BakedMopar
05-26-2010, 03:14 PM
IME anything over a 29" mono would be pushing it. That setup is proven in a 25" delta clone but in a OM29 it's close.
Jabbo
05-26-2010, 03:17 PM
then what whould I need to bump it up to?
Xfactor
05-26-2010, 03:26 PM
a 9xl will carry that boat
Xfactor
05-26-2010, 03:27 PM
Im pushin a 26 inch paynpak with a 6xl on 3s. An xl motor in my opinion will push that boat as long as the battery prop combo is right.
BakedMopar
05-26-2010, 04:15 PM
I'm not saying the motor won't push it. I would go to at least a 150amp esc for the bigger boat so you can prop accordingly.
ENCORE MAN
05-26-2010, 04:29 PM
I am running a Nemisis 8xl with an ETTI 150 IN A 26" H&M and the ESC barely gets warm. I had previously smoked a SEAKING and a TURNIGY 120 A in the same setup. You might want to spend more now and buy it only once. BG
Jabbo
05-26-2010, 04:51 PM
Hydra 240?
izzy7771
05-26-2010, 05:06 PM
maybe a turnigy 180? i have had nothing ever go wrong with any of mine. i have 4. would buy more too if i smoked one. run them on 3s to 6s all the time. i like em anyway and they arent really that expensive.
Make-a-Wake
05-26-2010, 05:10 PM
Jabbo - "then what whould I need to bump it up to?"
The fastec is 27" long...............an XL motor will push it fine. I'd go 9XL for 4s if i were you. I have a 31" Villain nudging 40mph with a 12XL on 6s.................an XL will really move that boat out well!
Jabbo
05-26-2010, 09:42 PM
How is the Etti 150 with bec?
ENCORE MAN
05-26-2010, 10:46 PM
THE ETTI 150 APPEARS TO BE VERY RELIABLE. I own two of them and have no regrets except with programming which takes awhile to figure out but once you get the rythmm, it is easy. BG
Make-a-Wake
05-26-2010, 10:55 PM
The turnigy 120a will run the XL motor just fine.....and up to 6s.......I own several, they are a great value............only$49 under my HK user login.
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8946&Product_Name=Turnigy_Marine_120A_Brushless_Boat_ES C
Xfactor
05-27-2010, 01:11 AM
If somebodys gonna sell me a 180 amp 360 burst for under a 100 dollars id be crazy not to get it it obvious that rite now the most success is being had with the turnigy/seaking 180s. if you worried about the amps I think you better go there. I mean I chose a turnigy hv 80 over a hv 100 because the 80 had more burst amp capability u have to really look at these specs but i bet the mystery 200 will hold up. I have a forcemax 60 in my atlas no problems. A elf hobbys 100 in my pak on a 6xl no problems. So its really hard to say but go for overkill get the 180 turnigy.
Xfactor
05-27-2010, 01:13 AM
I just wish they made a HV 180 for a price like that.
Xfactor
05-27-2010, 01:17 AM
Oh i didnt see what kind u originally said that swordfish stuff looks damn good on their website a 120 with them will do okay but my friend is rite when he says that the bigger amp speedo will give you more prop choice.
