View Full Version : New Turnigy Digital Charger Balancer
LiPo Power
05-19-2010, 07:40 PM
I just got one of the new Turnigy chargers and tested out on my new 2 x 4S Turnigy LiPo's. Works great, easy to use and has great digital display.
On the negative side, cooling fan is a little noisy but it sure moves the air very well inside of it.
Anybody else has one and would like to share their opinion?
Thanks
Robert
eboat
05-19-2010, 08:19 PM
If you have a big enough power supply can you charge 4 4S lipos at 5 amps each ??
LiPo Power
05-20-2010, 09:39 AM
Next time I will plug 4 x 4s and let you know.
I think 4 x 4s woul charge at 3Amp
Robert
JimClark
05-20-2010, 02:08 PM
How acurate is it and what voltage is it charging to?
Jim
teach
05-20-2010, 04:51 PM
Should charge all 4 packs at 3.4 amps. I only have 2s packs so the 3.4 amps is from what others have claimed. It's just 4 smaller charges built into one box. They all work seperate from each other. I have charged all 6 of my packs at 6 amps although I only got the one balance adapter. So if you buy one please remember to get a few more.
On the first go around the balancer was dead nuts. 6 packs all came in from 4.19 to 4.20. Verified using my voltmeter.
That fan does make some noise.
Over all in the very short time I have owned it's been perfect. Who knows on longevity.
calcagno45
05-21-2010, 02:40 PM
It's only 50watts per channel, which limits it to about 3.4amps per 4s pack.
eboat
05-21-2010, 02:48 PM
That is what is was wondering about
Looks like a good charger but to try and charge the 5000 packs will take longer when you can only go to 3.5 instead of 5 amps
LiPo Power
05-21-2010, 05:15 PM
...right, but you charging 4 on the same time!!! Or 4 diferent ones on the same time wthat would not be possible with single or duo charger....
I made one mod to my charger and cut the bars on the front of the cooling fan. It moves air much easier and I can feel better air flow now....
Charging 2 4S LiPos this pappy is not even getting worm but extra air flow allways helps...
I love this charger!!!
After the weekend I will be testing this charger all possible ways. All my LiPos are charged now and I need to drain them out to before my testing. Will update....
BDW guys!!! This charger is $99.99 for members!!! Regular price is $144.00
Robert
LiPo Power
05-21-2010, 05:22 PM
May I please ask how did you figer is 50 Watts per channel?
Thank You
Robert
LiPo Power
05-21-2010, 05:24 PM
Most of my LiPos are 2S so eureka!!! I can charge 4 of them at 5 Amps!!!
6S HYDRO
05-21-2010, 07:24 PM
50w per channel is listed in the specs, i only have mostly 2s packs too-so ive had my eye on this one as well.
LiPo Power
05-21-2010, 07:52 PM
...got it...
LiPo Power
05-25-2010, 09:56 AM
Test Charge # 1
4 x 2S, 5000mAh, 20-30C, 7.4V charging at 5 Amp on the same time. Works fine.
Charger after 6 minutes only got worm. So fare so good...
Next will be to see 4 x 4S batts....
Will post...
Robert
Charging of 4 bateries done in 60 minutes!!!
Meniscus
05-25-2010, 10:30 AM
That's definitely not something I would leave unattended! I'm glad to hear it's working well for you.
LiPo Power
05-25-2010, 10:51 AM
My charging is allways done under close supervision....
LiPo Power
05-26-2010, 12:02 AM
Well, works great!
Charging at 3,5 Amp each.
I will check time of charging at the end of it and post.
Robert
First 2 batterias were done after 40 minutes and second set 57 minutes.
Within 1 hour I had 4 4S lipos charged!!!! Great staff....
RandyatBBY
08-13-2010, 03:43 PM
Well, works great!
Robert
So what power supply did you use?
LiPo Power
08-13-2010, 03:51 PM
This one. Great Power Supply and on 4 x 4S LiPo charging only got a little worm and cooling fan never kicked in.....
Robert
Sailfish
09-01-2010, 08:49 AM
I bought one of these earlier this summer and regularly charge 4 - 2S 40C 5000mah at the same time. I converted an old computer power supply that will put out 24A @ 12V. I have no complaints, it is a great charger.. Just my .02...
LiPo Power
09-01-2010, 03:18 PM
Same here.... I use my PC 30Amp power supply often as back up or if charging 1 battery...
JimClark
09-28-2010, 12:00 AM
Where did you get this supply?
Robert
LiPo Power
09-28-2010, 12:02 AM
Which one Jim?
JimClark
09-28-2010, 12:30 AM
Post 18
LiPo Power
09-28-2010, 07:29 AM
Sent PM
