View Full Version : this look about right for the stuffing tube on homemade cat?
i dunno what the hell im doin but i think this is the general idea. correct me if im wrong... Dana
bonewar
05-19-2010, 06:55 PM
Dana,
The stuffing tube looks OK.
The trick to getting it right is as little of a bend as possible.
That way there is less friction on the drive line.
Bonewar :rockon2:
so lemme ask this.... since my transom os flush across the back, should i use a strut that is closer or further away from the transom...?
bonewar
05-19-2010, 08:40 PM
Dana,
I like to have my strut as close to the transom as possible
to help with prop walk issues.
The boat i'm referring to is a H&M MARITIMO CAT.
40" LONG 10.5" WIDE.
Your cat looks to be about the same size.
Running the strut behind the transom works 2
And allows for easy access to the strut if you need to adjust it.
Theirs a couple of ways you can do this.
with an in line rudder behind the strut
or an offset rudder beside the strut.
I like the in line rudder for more of a scale look.
Bonewar :rockon2:
Well I found a really cheap aluminum strut but it's set back, maybe I could redrill so the strut is right on the transom the do an offset rudder
Cheap or inexpensive?
Because you don't want cheap...
Try this, it comes with everything you need in the way of drive hardware except a coupler:
http://www.offshoreelectrics.com/proddetail.php?prod=ose-80085
Jon
thanks but they're out of stock. inexpensive was the word i meant to use lol
