View Full Version : Genesis maiden run
tiqueman
05-18-2010, 02:44 PM
Id say this boat has tons of potential. Handles waaay better than I thought it would have.
This run is straight out of the box. Guessed on the adjustments, cog, etc. Needs very little fine tuning.
Run was on 3S2P 2650 mah. Ran about 4 minutes temps were low 120s on esc and motor and 111 on the batts. No gps this run, but Id guess just inside the 30s.
http://www.youtube.com/watch?v=boWyWrZoxmQ
Shot w/ my new Sandisc micro cam
tomstoys2
05-18-2010, 03:16 PM
Nice video Scott! Pretty impressive for stock out of the box set up. I agree with you, seems to have some great potential.
Tom
Nice cat. Did you get it from HobbyKing site?
tiqueman
05-18-2010, 03:35 PM
Yes sir!
FighterCat57
05-18-2010, 05:18 PM
Nice! That's the same "bouncing" that the Apparition did out of the box. Dropped the strut down and it went away.. Looks like it handles well and certainly has the appearance of an FE!
________
BUY BUBBLERS (http://bubblers.net/)
Rumdog
05-18-2010, 05:42 PM
It's probably the low speed causing the bouncing. The faster you go the more air in the tunnel, the more lift. That equals less bouncing. It is faster thatn what I thought it would be on 3s though!
Brushless55
05-18-2010, 06:15 PM
Nice!
would 5000mah packs fit?
tiqueman
05-18-2010, 06:59 PM
Yeah thats what I figured I do as well. Drop it a bit. Right now its set, bottom of the strut at bottom of the sponson (set by table top)
Very true. And yes, it does better on 3S than I though it would as well.
Nice!
If I can get things wrapped up before dark, I will get a 3S2P 5800mah run in. Yes, 5000s' will fit with no problem. I ran my 2650s because they were charged.
Brushless55
05-18-2010, 07:34 PM
I think the bottom of your strut should be 1/4" to 3/8" from bottom of sponsons
the prop needs to unload some
tiqueman
05-18-2010, 07:42 PM
the prop nees to unload some
That is the norm, however, with it lowered the bounce went away. And where it was, it was about 1/32 of an inch from being as high as it will go without mods. Also w/ its original placement, It cavitated A LOT.
Brushless55
05-18-2010, 07:48 PM
but now I think is will load things up on the motor going below the sponsons :confused2:
tiqueman
05-18-2010, 08:46 PM
Yes it will. But the ride attitudes nice now. I will mess w/ it more tomorrow. Play w/ the cog and such. Then start changin props.
