View Full Version : Venom 2700kv and 2000kv Marine Brushless Outrunner Motors
Venom Media
05-17-2010, 06:55 PM
http://img132.imageshack.us/img132/6831/2700kvoutrunnermotorand.jpg
Hi Guys,
Our New King of Shaves P1 Fountain and C1 Offshore Cats are now coming with our new Brushless Outrunner Motors. These Marine Outrunners are designed for trouble free use and provide exceptional power using low amp draw and low operating temperatures thanks in part to the air-cooled can design that draws high volumes of cool air through the motor. The New Marine Brushless Outrunners use our new Clamp Style Motor mount system that uses one screw to securely lock the motors in place allowing for easy, vertical tool access. Both motors are capable of handling 2-4 Cell Lipos or 7.2 to 14.8 volts. The 2000KV motor has a 5mm shaft and a 37mm can diameter. The 2700KV has a 3.175mm shaft and a 27.8mm can.
Brushless55
05-17-2010, 09:45 PM
Hmmm, interesting?
brand new member from Venom... :spy:
they seem to only come around when they want to sell something! :thumbsdown:
tell us, are you, being the new one from venom going to stand behind any warranty?
skater368
05-17-2010, 11:04 PM
over night me 2 and 2 esc's
arrowskartax9
05-18-2010, 04:04 AM
Venom, How about giving your customers a boat [P1,C1] that is reliable hopefully to use.
New products are great but you need to back them up.
A lot of testing must be taking place with the P1.Still no confirmed release date.
Brushless55
05-18-2010, 09:58 AM
I don't think it's the testing holding it back, they are still waiting for the boat to come from china with these rc boats
they import their stuff, not much RnD goes on with venom :glare:
OshkoshMono
05-18-2010, 06:23 PM
Venom? Hello? Release date for the P1? My friend is dead set on waiting for one and I need someone to boat with. Chop chop, better beat traxxas to the punch or you are gonna loose sales like mad! I bet the traxxas 35-ish inch mono will be solid too...:ohmy:
Brushless55
05-18-2010, 06:27 PM
I'm betting on the new Traxxas Mono! :spy:
OshkoshMono
05-18-2010, 08:04 PM
Ya, I have to say Venom has some serious work to do if they wana "stay afloat" IMO. :lol:
Brushless55
05-18-2010, 08:27 PM
with the new Mono coming from Traxxas and the new Cat coming from Aquacraft..
and all the RnD Traxxas and Aquacraft are doing right now before they release these new boats.. yep they got my vote :thumbup1:
arrowskartax9
05-19-2010, 04:39 AM
Could also be the Traxxas for me to.
forescott
05-19-2010, 07:19 PM
I placed an order for the p-1 through towerhobbies months ago. If they push the release date one more time, I will be forced to cancel and order the traxxas mono! C'mon Venom, redeem yourselves!
forescott
05-19-2010, 07:23 PM
I think venom has pushed the p-1 aside and is concentrating on their new dirt bike right now. Too many new products releasing at about the same time!
05-19-2010, 07:28 PM
Hi Guys,
Ok, instead of bashing you, I have some questions.
Please post some weights and lengths?
Also, at 2700kv and 4s thats a ton of rpm.
Which boat have you tested the 2700kv motor in?
And for how many minutes did you run it on 4s?
arrowskartax9
05-20-2010, 07:50 AM
Good questions Steven!
VIKOS
07-07-2010, 03:17 AM
Traxxas have a good brushless. Would like to see it with the waterjacket though. I think it's rated at 2000kv. Which venom should do also. Forget these out runners cooling will be a big issue. Now if u use a water jacket and the fans then wow this thing will run very cool and reliable also.
forescott
07-07-2010, 08:34 PM
I am not counting on the factory setup to be reliable. I already have a replacement inrunner motor/esc for the p-1 when I receive it. I just cant see how an outrunner, which relies on air to cool it can stay cool in a hull that is sealed.
Rumdog
07-07-2010, 09:22 PM
Generally, outrunners can handle much higher temps and run efficiently still than can inrunners. I still prefer the inrunners as well.
Rumdog
07-07-2010, 09:24 PM
Venom Media. What a joke. Come on here to push your product, then disappear. Great info! Thier testing probably involved finding the motor on a HK site, and saying...hey that looks cool! Lets buy em' up!
Brushless55
07-07-2010, 09:29 PM
:rofl:
hobie
09-04-2010, 12:06 AM
What motor/esc did you order? On 4s after 10 min, mine is temping out at 120-130.
What would happen if I ran 6s on the stock setup? They say speed control is able to handle that?? But not the motor. A few people have said try it, just run for a min or two and temp it. I'm sure they're all saying it cause it's not their money.
Thanks.
forescott
09-04-2010, 09:52 AM
Thanks.
True, they just want to see what happens. The truth is 2000kv X 6s = 44,400rpm. That is waay too much rpm for any boat. The outrunner will heat up immediately trying to spin the prop that fast, and the speed control will heat up trying to produce the huuge amp draw that the motor will be asking of it. 4s max on the stock setup!
forescott
09-04-2010, 09:56 AM
I had the ammo 36-88-1280 and a turnigy120 that I was gonna put in the p-1 on 6s, but decided the stock motor is pretty good, and I dont think the p-1 would fit the larger props I was planning to use for my 6s setup. So I'm gonna stay stock for now. Got 43mph so far on my x442 prop. Want to try an x640 next.
hobie
09-04-2010, 09:15 PM
Awesome! Thanks or the info.
On the X640, I'm getting 40-41.5 mph
time to go shopping.
Diesel6401
09-04-2010, 09:44 PM
I wonder what type of mount is inside these http://www.etamiya.com/shop/thunder-880bp-white-pistol-transmitter-p-90018236.html.
