View Full Version : Bending stuffing tube
wizard122
05-17-2010, 01:06 PM
Hi whats the best way to bend a stuffing tube I Read some where you should heat the brass tubing first is these correct?:confused2:
bustitup
05-17-2010, 01:50 PM
if you haven't done this before it can be dificult....I ruined my first try
#1 slide the biggest flex shaft that will fit in the tube...this helps a whole bunch
#2 pour salt in the tube and cap off both ends
#3 heat it very carefully (till it changes colors) and use some type of protective gloves (heat)
with all three ways use finesse when you are bending
HYDROJERRY
05-17-2010, 01:53 PM
Boy i just bend it very slight with my hands and move down a hair and some more, until its enough maybe thats the wrong way but works for me,...
bustitup
05-17-2010, 01:55 PM
nothing wrong with that if you can accompish it without kinking it...the flex and salt are insurance with less chance of kink
blackcat26
05-17-2010, 05:41 PM
K&S makes these and they have worked well for me so far. Heat tube up with a torch in the bend then let cool by itself. Slap one of these over the tube then bend away......
egneg
05-17-2010, 05:54 PM
I posted a reply to this question at RRR.
wizard122
05-17-2010, 07:24 PM
Thanks you all. You guys always have the answers I need.
