View Full Version : Couplers
speedsport
05-13-2010, 06:30 PM
Any one know where I can get a 2.3mm motor to .098 flex coupler?
Jeff Wohlt
05-13-2010, 08:55 PM
Not flex but I can make one that is setscrew. You might find one across the pond but ti woud be metric on the 098 end probably.
speedsport
05-13-2010, 09:11 PM
Is there any reason that I could not use one with set screws for the flex shaft? As far as a metric one do you know who sells them?
JimClark
05-13-2010, 10:51 PM
I might have a couple of Jeff's I would be willing to sell. I need to check I ordered by mistake
Jeff Wohlt
05-14-2010, 12:38 AM
Thats right, Jim! Perfect. Just solder the cable end and you are fine. I can tell you one thing...Ed Hughey has set more records than anyone and has only used setscrew couplers all his life.
speedsport
05-14-2010, 01:23 PM
sounds good.
detox
05-14-2010, 01:55 PM
What is the trick to prevent set screw coupler from slipping on a .078 drive wire. Do you have to file flats on the wire?
JimClark
05-14-2010, 01:57 PM
OK just checked and I do have two never used (I ordered 2.3mm when it should have been 2.23mm). Jeff made them and there are 4 set screws for the flex and two on the motor shaft side.
They are 1.25 inches long and .375 inches diameter.
I think I paid $10.00 each. How bout $15.00 shipped for the both of them
Let me know
Jim
Jeff Wohlt
05-14-2010, 04:46 PM
Yep...flat spot on the wire to set the screws down on then you tighten the opposing set screws as well. Make sure you hit the flat spot. I file mine out beyound the coupler so I can see the flat area when setting the screws down.
speedsport
05-14-2010, 06:16 PM
I just double checked the motor and the flex shaft. The motor comes out to 2.26mm and the flex comes out 2.4mm. so 2.3 should work for the motor but I don't know about the flex shaft. Oh also I'm only looking for one.
Thanks every one
JimClark
05-14-2010, 08:21 PM
you would have to drill out the flex side of what I have. I am only selling both I have no need for them. it is up to you. You would be better off just having Jeff make you exactly what you need.
Jim
