View Full Version : vac-u-pickle!
thegreat1
05-13-2010, 05:29 PM
hey guys i recently took delivery of a new pickle. i have 2 motors i could use just not sure which to go with. i have both an ammo 2600 and a fiegao 9l. i will be running 3/4s. so which would better suit this hull? ill snap some pics of the begining. so far all i have done is paint the hull.
thegreat1
Jesse J
05-13-2010, 06:27 PM
what are your goals with this guy? race, sport, saw? speeds? batteries you wanna use? both sound border line 3S/4S, but with what props?
thegreat1
05-13-2010, 06:35 PM
i really don't know. i am totally new to hydros.
goals: mostly sport, hopefully begin racing with it.
batts:rhino 3s 3200's 2 paralleled to start 4s turnigy as many mah as will fit.
props: ??? you tell me
Rumdog
05-13-2010, 07:17 PM
Swap out those motors for a ul-1 motor and run 4s. a x440/3 would be good. 4s is too hoy for those motors really.
thegreat1
05-13-2010, 09:48 PM
will either of these motors run ok on 3s? i already have both that is why i ask. if not then can i safely run the ul-1 motor with the xpower 100a esc? i ask because if i end up putting that motor in the pickle i will put the ammo or fiegao back into my rio ep with the hydra 120. that is where the ammo/ hydra setup resides right now.
Rumdog
05-13-2010, 09:52 PM
The X-power would be great with the ul-1 motor. Those motors would both work on 3s, but prop size would be more limited.
thegreat1
05-13-2010, 09:53 PM
needing bigger you mean or what?
