View Full Version : Parts list for an EKOS hull only project?
FighterCat57
05-08-2010, 09:12 AM
...or and RTR re-build.
Can anyone help build a hardware link/list for the EKOS hull? This would work for the twin motor TLR Apparition too, as they have identical sponson transom & overhang measurements.
Not for an upgrade to the stock, but a complete replacement/new setup.
Drives/Tubes/Dogs
Motor Mounts
Stingers
Rudder & Mount
________
Vaporizer Review (http://vaporizer.org/reviews)
Jeff Wohlt
05-08-2010, 09:29 AM
I have all of it except for the stingers and rudder but those can be gotten easily.
I do not know the stinger length but I have some 70mm coming which seem long enoght to me on my HOR cat and will be modified for 3/16" shafts.
I would run 150 cables if I were you just to buiuld it really strong...or run wire drives. Obviously mine run wire.
I am running a 8XL with 4S in my HOPR cat on 062 wire and bearing strut and she screams. Just testing how the 62 holds and no isssues yet. Running no liner.
http://www.youtube.com/watch?v=RM8keupHaHw
FighterCat57
05-08-2010, 09:41 AM
The stingers are 70mm, exactly.
Hey Jeff, let's put together a complete hardware "kit". I'll be the first to buy it! =)
________
Honda capa (http://www.honda-wiki.org/wiki/Honda_Capa)
Jeff Wohlt
05-08-2010, 10:01 AM
Would that be with 380 XL motors or 540 motors? I ask because it may be a different set up for cables.
I would like to see some 540 motors mounted and 150 cables used to the stingers with 3/16" prop shafts...same as many HOR cats now use.
I probably need to get another hull and build a twin to see hwo things work out for motor mounts, etc.
FighterCat57
05-08-2010, 10:16 AM
I'm going with 540 motors and the motors I'm using in this boat have 540 & 380 bolt holes. Fortunately I can use the stock motor mounts. Should leverage the 4mm taps for cooling... There's just enough room for a threaded "L" like these: http://www.offshoreelectrics.com/proddetail.php?prod=etti-a030
I've got a few projects going on, so if you want to use this hull, you're welcome to.
________
Toyota Gz Engine History (http://www.toyota-wiki.com/wiki/Toyota_GZ_engine)
FighterCat57
05-10-2010, 09:14 PM
HOTR has complete stinger assemblies for $35 a side, which includes the 4mm drives, dog, spacer & prop nut. The 5mm-4mm collets are $8 each The 95mm rudder assembly is $18 and the 540 or 380 motor mounts are $3.50 each for basic motor mounts that fit in the belly of the sponsons.
Grand total of about $120 shipped.
________
Girlfriend Pic (http://girlfriendpics.org)
FighterCat57
05-14-2010, 08:11 AM
FYI- Jeff has the replacement bearings for the stingers.
Miller & Boca bearing have them too, but more expensive ones.
________
SELL VAPORIZERS (http://vaporizeraffiliateprogram.com)
