View Full Version : EKOS C1 Dual Motor Upgrade!
FighterCat57
04-30-2010, 06:59 PM
It's an almost bolt in job.
Two Turnigy 120A ESC's & Two HXT 36-56 2700kv Inrunners
The 540 sized motor comes with two different bolt patterns. Which allows for installtion in both 540 and 380 mounts. Leaving the EKOS mounts in-tact.
Modify the coupler for the 5mm shaft, shorten the drives about 6-8mm and it's a runner!
________
BUY SOLO VAPORIZER (http://www.vaporshop.com/solo-vaporizer.html)
FighterCat57
05-01-2010, 08:59 AM
Just a base, but I put the GPS on it and with a 2-3" chop hit 38.8 on 3s with 31 minutes of run time... Didn't feel any heat at all when I popped the top afterwards, so I think 4s will do just fine and pick up about 10k RPM. It's rated to 18v, so might even try 5s.
I haven't calibrated the ESC's yet and was very conservative on the throttle for the first run.
The wind picked up and there's too much chop now, so will try again in the morning. =)
________
Penny stocks to watch (http://pennystockpicks.net/)
pmisuinas
05-01-2010, 11:05 AM
What props are you using?
FighterCat57
05-01-2010, 11:30 AM
Just the stock plastic props.
________
FORD MOTOR COMPANY (http://www.ford-wiki.com/wiki/Ford_Motor_Company)
pmisuinas
05-01-2010, 11:37 AM
Wow, sounds like you could pick up a lot of speed going to a larger prop, motor should take it easily--maybe the CF-40s? Anyway, I am on the Hobby King web site and of course the motors are out of stock--can't seem to find upgrade motors anywhere right now...
Rumdog
05-01-2010, 11:41 AM
here ya go: http://www.offshoreelectrics.com/proddetail.php?prod=fei-380-xL&cat=116
FighterCat57
05-01-2010, 11:50 AM
Helz yeah. The 10xl.
If I had known I was going to be replacing motors in the EKOS and didn't already have the Inrunners ordered, I would have gone with the 10xl's. They can handle 6s.
________
POT NEWS (http://potwire.com)
FighterCat57
05-01-2010, 11:51 AM
Yeah, it's running really wet, I haven't adjusted anything yet.
________
Mykey (http://www.ford-wiki.com/wiki/MyKey)
pmisuinas
05-01-2010, 12:03 PM
Yeah, but I was looking for the 9xl because I have a bunch of decent 4S packs. I also would not want to put the weight of dual 6S packs in this boat. But I guess the Kv difference between the 9xl and the 10xl (10%) is not that big (especially since 10xl are available now), maybe prop selection could overcome that...problem is I would have little to no idea how to pick a prop, as I am new to FE...
FighterCat57
05-02-2010, 08:36 AM
OK, so it's a windy morning here at the beach, but I was able to find a small oyster bed alcove with 1-2" chop. Best I could find with a 15mph wind.
51.2 MPH peak on the GPS on two separate 4kMah 4s 20c packs. About 20 min of runtime. I'm thinking if I parallel the cell packs using higher C ratings, it'll do much better. I have some 4kmah 30c packs to try. My bigger 5k 30c's don't fit in the hull holders.
Still haven't calibrated the ESC's and wasn't able to hold the trigger for more than a 1, 2 count, then had to get off quick as it was jumping the chop against the wind. Not enough room to do speed runs with the wind as it was towards the shallows.
A little more in line with what is expected of this boat and I'm sure there's a few more MPH by tuning it right. :thumbup1:
________
Honda c71, c76, c72, c77 dream (http://www.honda-wiki.org/wiki/Honda_C71,_C76,_C72,_C77_Dream)
Igoreski
05-02-2010, 09:13 AM
I was looking at those Blue lipos you have because they fit great.I know your run times were long,did the battery get hot.I was holding back on those packs because of the 25c rating.
FighterCat57
05-02-2010, 09:30 AM
When I ran the 3s 25c packs, I didn't notice much, if any heat.
When I ran the 4s 20c packs, they did get warm, but not hot to the touch.
Next time, I'm going to run the 4s 30c packs and put them in parallel. Still haven't made my "X" connector.
________
Toyota Ecom Specifications (http://www.toyota-wiki.com/wiki/Toyota_eCom)
Brushless55
05-02-2010, 12:22 PM
You would not want to run 6s on the 10XLs !
that is ment for the lower kv motors :thumbup1:
vasy
05-02-2010, 01:52 PM
So you find those cheap 540 Turnigy motor work very well on both 3s and 4s?
Seems venom have a lot of melting lately, maybe a bad batch.
FighterCat57
05-02-2010, 02:35 PM
See post #26: http://forums.offshoreelectrics.com/showthread.php?t=13704
IDK from experience, just what I read.
The HK's seem a bit slow on 3s, but really come alive on 4s.... And so far, much more reliable than the motors that came with it.
Wait a few days, I'll run a few battery packs through it and tell you more.
________
Extreme Vaporizer (http://extremevaporizer.info)
Brushless55
05-02-2010, 02:40 PM
Get some glasses, those are 540s in that cat not 380s.. :rofl:
big difference! :rockon2:
vasy
05-02-2010, 02:57 PM
So far does it look like they are at about the same speed as stock?
I think stock were rated at almost the same KV.
FighterCat57
05-02-2010, 03:18 PM
AH, *SIGH*. :doh:
Thank you for the correction...I'm still learning. :o
I really can't tell you. The stock ones didn't run long enough to get a reading. :mad:
________
Civic (Eighth Generation) (http://www.honda-wiki.org/wiki/Honda_Civic_(eighth_generation))
Brushless55
05-02-2010, 07:11 PM
I think the stockers are 2850kv and the Feigao 380 10XL motors are 2352kv
the Feigao motors are much more able to run 4s over the stock motors :thumbup1:
vasy
05-02-2010, 09:25 PM
Cool. I'd think 540 would have more torque so you would be able to spin larger props, so unlike stock 32/36mm, go with like x438/x440 that would make up for small difference in KV.
FighterCat57
05-04-2010, 05:29 PM
One of the Turnigy ESC failed and HK is out of stock, so I found a Seaking 120 which should pair up with it as a replacement.
I put in a pair of Aquastar's, but one of them blew up on the bench.
Will update more when I'm actually able to get some good runs in, with an ESC that actually works.
________
Launch box vaporizer (http://mflbvaporizer.com)
vasy
05-04-2010, 05:34 PM
That is just wrong..... check www.hobbyhot.com (http://www.hobbyhot.com/electric-speed-controller-c-282.html) for good price on seaking esc.
They sell for less with programming cards then without :confused2:
FighterCat57
05-04-2010, 08:42 PM
Yeah, that's the one I picked up. We'll see if it get's here this month.
________
PROTECTION AND INDEMNITY INSURANCE FORUMS (http://www.insurance-forums.org/protection-indemnity-insurance/)
FighterCat57
05-10-2010, 08:36 PM
Still not here... BUT...
...Venom sent my 60a ESC's back! So... I did a little bench testing with the new HK 2700 36-56 motors. I've been using an upside down pepsi bottle with silicone line through a hole in the cap to make good water flow to simulate in water use. Nothing full throttle, but calibrating the ESC's and making sure both props start & stop at the same time.
The port side motor was barely moving and drawing quite a bit of current. Seems that when I was experimenting with 4s, it killed it. No surprise there.
Fortunately, when I ordered these, I ordered 4 of them to have extra. I soldered up an "X" connector to combine both battery packs and eliminate the need for more than just two battery connections. The only connections now are at the packs and at the motors.
So, the setup is Dual 60a ESC, 2700Kv 36-56, 36/3 Props on 3s2p 50c 5k mah about 29k RPM max.
With any luck, I should have it ready for the water by morning.
________
Vaporizer guide (http://howtomakeavaporizer.info/)
FighterCat57
05-11-2010, 01:40 AM
Some updates of the build:
I used a small piece of 3/16 tubing as a splatter guard. A dab of CA is holding it in place on the drive tube mount.
The couplers have been drilled out and tapped to use 4mm threaded stainless steel set screws and fit on the 5mm motor shaft.
Notice the holes in the top of the motor mounts? They are water cooled mounts, just not installed. So fittings are on the way to cool the mounts.
Like my Traxxas Rx? It's literally fully encased in silicone and is completely water proof. The inside is completely packed with silicone, so even if water get's in the connectors, it has nowhere to go as the bottom of the connector space is sealed too. This has worked while completely submerged in salt water in one of my cars. Pretty cool.
The batteries are older smaller packs, but very light. The whole boat weighs in at 2780 grams, fully loaded. The COG is set at 8 1/4" and stingers are at 1/2 -1 degree positive.
The ESC's are shrink wrapped together using battery pack wrap and in the nose cowl. I used pieces of cut sponge to fill the aft sponson bellies around the drive tubes. Water seems to leak in through these drives fairly fast.
The Rx ESC connectors & Y adapter are encased in silicone and shrink wrapped for a good seal.
Using the stock props with aluminum 4mm cones....
________
Grey'S Anatomy Forum (http://www.tv-gossip.com/greys-anatomy/)
FighterCat57
05-11-2010, 01:44 AM
More photos:
The bottle is used to flush the system with an MPPL anti-corrosion mix. Good stuff.
________
CHEVROLET CAPRICE (http://www.chevy-wiki.com/wiki/Chevrolet_Caprice)
FighterCat57
05-11-2010, 08:14 AM
The water is choppy and there's a 20mph wind, so had to take it easy against the wind. Fortunately the current was going with the wind, so was able to make some good passes.
I think I have everything setup right, it's doing full boat skipping across the waves and landing perfectly without skipping a beat! Against the wind it's lifting up a bit but the chop is about 4". I was skeptical about actually letting it out in these conditions.
Very little water in the boat, sponges were basically dry, but some worrysome splash on the GPS. I think the hull hatch is still leaking through the windows.
Water conditions were so much nicer yesterday!
With the Stock 60a ESC, HK 2700Kv Inrunners, 36/3 1.4 Props and dual 3s 20c 4k packs:
35.1 MPH
2.2 miles
11.35 minutes (over 10 mph)
~100 degree motor
~95 degree ESC
~100 degree Batteries
Didn't get an amp/watt reading as I'll need to setup X connectors on my amp meter. (for dual batteries and dual ESC)
Easy more run time ending Voltage was still up at 11.25v and these were my cheapie 4k 20c packs.
Might take a drive out to the pond on mainland later today. it's surrounded by trees, so is almost always fairly calm.
So to answer your question Rumdog: No, I had to replace the motors to run the boat successfully with the stock setup.
________
Vaporizer Help (http://vaporizer.org/forum/vaporizer-questions/)
FighterCat57
05-11-2010, 12:39 PM
Run #2 today at the City Center Pond... Same config, except larger 3s 25c 5kmah packs.
It went well for a change. I ran it for about 16.4 minutes and it was nicely planted and easy to control. I brought it in simply out of fear something else would break on this thing and the run had been going well. It's pathetic to be this paranoid of it breaking again. Still have a full 11.2v when done.
Temps were good, motor 100, ESC 115, cells 120. Covered 2.77 miles with a whopping top speed of 39.3MPH... Fast enought to literally suck the paint off... or um... let it fall off? :confused1:
________
Chilean cooking (http://www.cooking-chef.com/chilean/)
FighterCat57
05-11-2010, 03:08 PM
Decided to push it and get another run in today in the channel. It's a dock that's partially protected and dredged for large ocean charter boats to dock. The mangrove trees provide a good amount of wind protection and the water is fairly shallow by shore, which equals, somewhat stable water conditions. Hard to find today as it is really windy. The current was going against the wind.
Using the same setup as the one at city center above, I hit 38.2, however covered 4.2 miles with approximately the same run time of 16.2 minutes. Motor, esc, batt were 110, 115 & 130 respectively. With the battery being hot at 130, I'm going to move up to a 30c pack for a 3s2p 60c parallel setup. As soon as my OSE order get's here, I'll break up a 6s pack and get it going.
I REALLY want to try 4s with this setup, but I am fairly certain it's too much prop for that kind of RPM and only 60a esc...
I'm considering using the 32/3 1.4 plastic props that venom sells for $3... I'd like to get this boat up in the high 40's, but don't want to kill it to do it.
I'm changing to 1800Kv/120a on 4s when the parts come in... Perhaps even 5s, if I can fit the packs under the hull.
PS- the 3/16 vinyl tubing is working excellently as a splatter guard. No more grease splatter!
________
E53 (http://www.bmw-tech.org/wiki/BMW_E53)
FighterCat57
05-12-2010, 09:42 AM
Finally!! Here it is! My FIRST full charge run! It came in really dry and everything was cool, except for the battery packs. I think that 25c is just not enough juice for this boat on a full throttle run. Did well at varying speeds, but today I basically just held it wide open and had some fun!
For the first time, I went out and ran until the LVC kicked in! Sad. Isn't it? But fun none the less. =)
Top speed: 39.0
Run time: 15.2
Miles: 4.2
ESC Temp: 100
Motor Temp: 90
Pack temp: 130
OSE's package should arrive today and I have a 6s1p 35c battery pack that I'm splitting into two 3s packs, hopefully the good water lasts a few hours today.
The only thing that broke on this run was the epoxy mount on the front of the battery box! :doh:
________
Buy Hot Box (http://www.vaporshop.com/hotbox-vaporizer.html)
FighterCat57
05-14-2010, 09:55 AM
- Just an update, waiting on parts for the bearings on the stingers. I'm going to try the Boca Ultra Seal bearings and work on packing the stingers more effectively. Getting another set of bearings as a backup too.
As soon as Jeff get's the wire drives ready, I'll get those up and running. =)
I'm pretty sure the drives were not spinning freely enough and it's all me. I was upset and forgot to pull the drive and clean it the first time it broke the motor... I'm sure the salt water kilt the bearings by sitting in it for a week. Even with MPPL in the tubes, I should have pulled out the drive and soaked the bearings. Although, they are very cheap bearings and I'm sure the salt water would have eaten them up soon anyway...
________
Green Crack (http://trichomes.org/marijuana-strains/green-crack)
Jeff Wohlt
05-14-2010, 10:13 AM
I really think the 062 wire drives may be a real hot set up. No stuffing tube issues and just two coupler changes. Less resistance and no right left crap on cables. Would be perfect for 3 and 4S set ups.
They will be 4mm stubs x 062 drive on the EKOS page.
FighterCat57
05-14-2010, 10:18 AM
I have two 1800Kv 100amp motors I'm putting in here on 4s. So um... yeah. Just send me a paypal invoice when they are ready.
________
Jeep Hurricane (http://www.dodge-wiki.com/wiki/Jeep_Hurricane)
Jeff Wohlt
05-14-2010, 10:20 AM
You should be able to run X442 l&R props then and still stay cool.
FighterCat57
05-14-2010, 11:28 AM
That's the plan. I have dual Aquastar 120's that should make it a good balanced setup. I'm planning on pulling the battery box and re-attaching it with velcro to find the right COG and quite possibly an Eagletree Seagull setup to monitor everything. :thumbup:
Its amazing how much I've picked up about boats here in the past few weeks. Now let's see if I can apply it and make it all work.
With the new cable drives and fresh bearings, it peaked at 40.2 MPH on calm waters. ESC and Motor temps were right at 100F and run times are hovering at 15 or so minutes on dual 25c 5k and 30c 5k 3s packs respectively.
________
Alberto Massimino (http://www.ferrari-wiki.com/wiki/Alberto_Massimino)
netik racing
05-25-2010, 02:21 AM
were did you get the motor from i can't find them anywhere??????
FighterCat57
05-25-2010, 04:34 AM
Search "SeaMonster" and match the amps/Kv to your ESC's.
Here's an example:
http://cgi.ebay.com/BL2845-KV2700-Water-cooled-Brushless-Motor-RC-Boat-/130393904038?cmd=ViewItem&pt=Radio_Control_Parts_Accessories&hash=item1e5c1513a6#ht_3185wt_1137
________
Toyota 3S-Gte Engine (http://www.toyota-wiki.com/wiki/Toyota_3S-GTE_engine)
FighterCat57
07-30-2010, 11:08 AM
Some updates...
With the 36mm props, it loses ~8mph. The high RPM low torque setup prefers the 32mm props. Typically 53 mph on the smaller props...
She goes, but sucks at turning compared to my other cats. :huh:
FighterCat57
08-14-2010, 03:38 PM
FYI- these motors are back in stock at HK. The stock photo is inaccurate;
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=5146
Not much for torque, but they have done well on 3/4s with smaller props. :cool2:
They have the 19mm and 15mm bolt patterns.
JPriami
08-14-2010, 04:06 PM
where did you get those blue lipo 4s 40K 30C packs?
FighterCat57
08-14-2010, 04:54 PM
www.hobbypartz.com
Not sure I'm sold on them though. I prefer the Turnigy and am liking the new Nano-Tech packs.
The blue lipos have all "puffed" a bit, same with the Zippy Flightmax batteries.
VIKOS
08-14-2010, 05:18 PM
puff is not good in the lipo world at all...be careful!!!
Skullcracken
09-15-2010, 09:45 PM
So does that setup run okay on 4s? I am all stock except I have 85 cont, 135 peak esc's to each motor. Can stock motors run on 4s? My other cat is 55mph+, makes my EKOS a little boring. Have you done anything further since ur last setup? I want to increase speed, but not crazy to where I sacrifice reliability.
FighterCat57
09-15-2010, 09:55 PM
The stock motors fry on 4s. It's been proven with little exception. The stockers fry on 3s too...
My EKOS pulls ~53 amps peak/side on the tell tale amp meter after a run. The only issue is the bearings don't last long at that RPM.
I have mine for sale cheap if you're interested. I'll split it up if you want it. $200 shipped, less radio. http://forums.offshoreelectrics.com/showthread.php?t=17625
FighterCat57
12-22-2010, 09:32 PM
Never did find any good motor mounts for the EKOS. So... I had some made with 25mm spacing for 540 sized motors. Can run any of the 36mm canned L-XL series motors or 3126 series outrunners. I call them TwinCat Medium Motor Mounts (http://fightercatracing.com/index.php?page=shop.product_details&product_id=34&flypage=flypage.tpl&pop=0&manufacturer_id=5&option=com_virtuemart&Itemid=1)
Literally, just grind out the stock mounts and epoxy the new ones in place.
:thumbup1:
Brushless55
12-22-2010, 11:00 PM
very nice man!
forescott
12-23-2010, 05:44 PM
How is that fiberglass piece attached to the aluminum?
FighterCat57
12-23-2010, 05:52 PM
There's two countersunk M3 TSHCS's underneath that hold it together.
LarrysDrifter
12-23-2010, 06:25 PM
Id use green or red locktite on those screws.They are nice mounts,but they are similar to EKOS mounts in that they bolt together in the same fashion.I had the 2 screws in the one of the EKOS mounts back out and had to cut the mount out for the 3rd time.I was using blue locktite.I switched to green and they havent budged yet.
FighterCat57
12-23-2010, 06:29 PM
Yeah, I recommend using loctite red. It's worked well thus far. Green would be good too! I should add that info.
forescott
12-23-2010, 06:52 PM
Weird, I've never had an issue with mine. OOPS! shouldn't have said anything. Now they will come loose for sure.
LarrysDrifter
12-23-2010, 06:55 PM
Ha ha.Get the dremel ready.
FighterCat57
12-23-2010, 07:08 PM
That's because you have this weird magic like luck with with the VenKOS. :huh:
He he.
BTW- Now that I know what I know, I don't carry the animosity I once had two-ard des kompaneeez. :tape:
tomik78
01-02-2011, 04:24 AM
Here is my set-up of the similar boat.
6s voltage speed with 1/2 throttle reach over 100 km/h.
Prop 38/1,5/3 RL. I recommend! :thumbup1:
http://www.youtube.com/watch?v=3hnwKCiPF48
forescott
01-02-2011, 09:11 AM
Nice clean setup! Are those the 1800kv versions of the typhoon outrunner?
tomik78
01-02-2011, 09:57 AM
yes they are.
forescott
01-02-2011, 11:12 AM
Did you mod the mount for those???
Boomer
01-03-2011, 11:13 AM
Please show us a few close ups of your clear plastic hatch cover. I have been considering something like that for my EKOS. Does the stock canopy fit over it? How thick is it?
Any details you can provide would be great.
Thank you
Boomer
tomik78
01-04-2011, 01:15 PM
Motormounts are not modified, but to them have added water cooling. Engines have been made to the fitting plate, so that they may be attached to 19 mm motormount.
The clear plastic is 2.5 mm polycarbonate. I have taped the clear plastic and then the original canopy and it fits well, the canopy leaves just few millimetres up from edge.
FighterCat57
01-04-2011, 01:23 PM
Nice! That will help prevent sinking in event of a window blowout. It's happened before when the hull submarines into a wave.
Boomer
01-04-2011, 01:50 PM
Tom
Thank you for the details of your clear inner hatch. It appears that it causes a slightly higher than a flush fit. Is there any more or less water intrusion with your set up?
On my EKOS there are two pins in the front of the canopy and two magnets on each corner of the rear that are provided by the factory to keep it in place, but they provide no seal what so ever, so tape is mandatory to keep the water out.
I think I can find a very thin piece of clear plastic sheet to fit under the pins, so that shouldn't be an issue. I am thinking of replacing the magnets with push locks on each of the two rear corners to keep better pressure on the sealing areas. I thought about forming as gasket around the lip of the opening which would really help. The EKOS canopies are famous for warping in different temperature conditions. I fount that it helps reduce this tendency if you keep in on the boat and by putting some weigh on it while it is not in use.
With two 3 cells in my boat, the rear lip of the canopy is just a few hairs from the water line. I have a set of 4 cells that may put that area underwater when the boat is not moving. So, a good seal is critical.
Thank you
Boomer
Livewire121
09-26-2012, 04:10 PM
Hey Tomik78 who makes those props?
Skullcracken
09-26-2012, 08:01 PM
[QUOTE=FighterCat57;180076]Just a base, but I put the GPS on it and with a 2-3" chop hit 38.8 on 3s with 31 minutes of run time... Didn't feel any heat at all when I popped the top afterwards, so I think 4s will do just fine and pick up about 10k RPM. It's rated to 18v, so might even try 5s.
I'd change to collets if you go 4s or 5s. Those couplers wouldn't hold the drives on mine when I went up to 4s with 40mm props, with 2800kv motors. That thing will scream on 4s or 5s.
This is my old EKOS on 2800kv motors but they're only 28mm diameter motors. 50mph on 4s.
http://www.youtube.com/watch?v=K2-HVA_7V28
Livewire121
12-03-2012, 01:49 PM
Well I was able to get some running in this past weekend. I was able to have the boat log a top speed
of 58 mph on my radar gun! I know I would have broke threw the 60mph mark . If my friend had been
able to register the boat with the gun on the first passes, when the batts were at their peak. The 58mph
was the last pass on those batts. My setup is a little different then the setups I've seen for the EKOS.
High voltage was the route I took, 2190kv motors, 6s two 3s 3800mah 50c packs in series. The props
were 442's that are sharpened/balanced, they still need to be detounged tho.
Temps were motors were in the low 80's, esc's were in the low 90's, and the batts were in the 100-110
range. Bout time I started seeing some results!!!
Livewire121
12-03-2012, 04:23 PM
Any opinions on the accuracy or inaccuracy of using a radar gun would be appreciated.
