View Full Version : Etti Brushless Navy Race 150 Opto
siranger
04-29-2010, 05:51 PM
How is the quality of this ESC ??? dont have any experience with it.
Scott T
04-30-2010, 05:13 PM
Mine is rock solid. Set up is:
Delta Force 33" mono
Neu 1515/1Y
Octura X442 or M445
Thunder Power 4S 30C 5,000 mAh.
Throttle control is not as nice as a Castle, but it's also quite a bit cheaper.
tiqueman
04-30-2010, 09:17 PM
Ive got 2. Good ESCs But I agree about the throttle control.. Wish it was a little better.
K.R.Joye
06-23-2010, 08:57 AM
Just got a ETTI 150 Opto can someone confirm the second detachable 2 wire lead is for a on/off switch. If so is the esc On or Off until you conect the circuit?
THANKS!
06-23-2010, 10:19 AM
The loose wire in the bag is a adapter to connect the power analyzer.
K.R.Joye
06-23-2010, 10:27 AM
da!
Thanks STEVEN!
jb1234
06-23-2010, 08:52 PM
I just got my 150 opto Monday. Hooked it up with the fiago 13xl, castle bec and futaba 2pl-24g radio. The reciever and the bec light up, the servo works but nothing from the esc or motor. No lights sound or motor movement. I'm prety sure the esc is bad but I thought I would see if anyone had any suggestions before I return it. It has the cap board added to the esc. Also it sparks like the caps arw charging but that's all it does
K.R.Joye
06-24-2010, 08:16 AM
Very impressed with the quality and waterproofing on the Etti 150 opto. I shortened the battery and motor leads, keep the cap board close to the ESC to cut down on overall length. Soldered on my 5.5s, plugged it in, turned on my 2.4 gig then Rx `Beep Beep' armed and ready! Nice thorottle range and startup. I'll water test it next week after the foul weather clears up.
KRJoye
