View Full Version : Vs1 fe
longballlumber
04-28-2010, 05:14 PM
I figured that I would post some pictures of my converted VS1. I've only ran it at one club race, but I gone back thru it again and should be testing again on monday.
Later
Mike Ball
longballlumber
04-28-2010, 05:15 PM
Few more
rchippie
04-28-2010, 05:33 PM
Looks good . Im almost finished with my VS-1 conversion.
Brushless55
04-28-2010, 06:50 PM
nice looking lower!
bigwaveohs
05-02-2010, 05:51 PM
Did you cut through the deck and styrofoam for the electronics box or is the box mounted on top of the hull/deck? Can't tell from the photos...
longballlumber
05-03-2010, 09:08 AM
Yes Sir,
I cut thru the deck and removed the foam. You need to get the CG as low as possible. Make sure you support the bottom sheeting after removing the foam!
Later
Mike
bigwaveohs
05-18-2010, 12:04 PM
Later
Mike Ball
I haven't had much luck using silicone tubing and wire ties to keep water out of the steering cable tubes. I was thinking about trying these...
What has been your experience?
longballlumber
05-18-2010, 01:12 PM
Those should work fine too...
Later
Mike
Chuck E Cheese
05-18-2010, 01:28 PM
this is how i do it and it doesnt leak a drop. it is wire through the brass tube then heat shrink. i use small rings or fuel tubing to insure the heat shrink doesnt slip.
bigwaveohs
05-18-2010, 03:19 PM
I too use heat shrink for the motor wires, but I was wondering about the steering cables. I tried running the cable through silicone tubing with tie wraps, but it still leaks if I flip the boat.
I am thinking about replacing it with bellows that would expand and contract like an accordion.
longballlumber
05-18-2010, 03:55 PM
One trick you can try before swapping out to radio box seals… stuff the open end of the fuel tubing with thick grease where the steering wire goes in to the tubing. The grease may be enough to seal that area
Later
Mike
Chuck E Cheese
05-19-2010, 04:02 AM
all i use is the housing that comes with the cable with a light coat of grease. i use the dubro 1/16th cable on all my tunnels for the throtle and never leak even a drop...
