View Full Version : 5.5mm connectors
teddyboy
04-13-2010, 09:35 AM
I am changing out the electrical connectors to the 5.5 mm bullet connectors. Does anyone have a particular way to solder the connectors and an application recommencation to the shrink tubing installation?
BHChieftain
04-13-2010, 09:56 AM
On this blog there is a video of soldering connectors:
http://rcboatsbypetere.blogspot.com/
I'm new to this, and just installed some on my lipos and motor, some pics are on this thread.
http://forums.offshoreelectrics.com/showthread.php?t=13793
The battery and motor wires were pretty easy-- these were thick wires (about 10g), so I tinned the wires, then inserted them into the connector, then heated the whole thing up, then added a little more solder.
Key thing is to tin the leads before you solder them into the connectors.
On the shrink tubing, I used my gas stove to heat it as I don't have a heat gun--- worked well.
-Chief
teddyboy
04-13-2010, 03:06 PM
Thank you for the quick response. Just learning-electrics.
detox
04-13-2010, 08:36 PM
You can eather hold the bullet connector using Vise Grip pliars or you can drill holes in a block of wood to hold them while soldering. A cigarette lighter or hair dryer works good on heat shrink tubing.
Diesel6401
04-13-2010, 09:34 PM
Best thing I purchased for soldering was a set of helping hands. I was wondering around Harbor Freight oneday and spotted this thing and it helps a bunch. Best $6 i've spent in a long time. If you have a Harbor Freight near you def check it out.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=65779
Heat shrink needs: ( I use just a regular Bic lighter, for the heat shrink)
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92300
O while your their grab a prop box :tongue_smilie:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=90243
teddyboy
04-14-2010, 08:08 AM
All of the folks on OSE are the best. I really appreciate getting all of the great responses, as I am learning the electric ways. I will really have to work to mess up the installation after all of this great information.
Thanks to all that responded.
longballlumber
04-14-2010, 08:44 AM
I would recommend using a WOOD close pin to hold the connector. Using a wood close pin will keep all of the heat in the connector itself, and not transfering to additional metal objects (ie. pliers, helping hands)...
Later
Mike
Jeff Wohlt
04-14-2010, 08:55 AM
I use a torch on mine. Fill the connector and stick the wire in to touch the bottom. I put my clip over the filler hole. Works fast and great.
