View Full Version : some testing of vs1 and MM for sport running
ozzie-crawl
04-04-2010, 07:26 AM
VIDEOS ARE FROM PHONE (no zoom) and there loaded directly from phone to you tube so phone compresses file
doing some testing running sport setup to get longer run time as i dont race.
first up is my vs1 running a scorpion 3026 1900 kv on 4s 30c 5000 zippys
m642 prop, esc is mystery 100a with cooling plate, timing set at 15 deg timing.after this run motor and esc at caps were under 40c (100f)
should be good for 3-4 minutes of fun :banana:
Xlj3sr6yLs0
ozzie-crawl
04-04-2010, 07:36 AM
this is my mean machine, same deal setting up for more run time.
set up is feigao 8xl on 4s 30c 5000 turnigy, mgm 12024 esc, x637
temps after run were 43c (109) motor at end bearing,40c (103f) esc caps)
should also be good for 3-4 minutes
during the start of the run you see it stop in the water for a acouple of seconds as the steering was not rite,thought it was my exponential set wrong but when
i got it back after the run the rudder had hit some thing at the start and was angled back about 15 deg, and yes i did hit the tree branch
otvkm4GjiOg
Xcesive8
04-04-2010, 09:56 AM
Bloody Tree's!!
ozzie-crawl
04-04-2010, 10:02 AM
yea makes it hard to see for us, think acouple may fall over soon :spy:
least we will be able to see our boats when they turn :eek:
6S HYDRO
04-05-2010, 12:16 AM
"with cooling plate set at 15 deg "
is it any faster with the colling plate set at 20 degrees? J.K:laugh:
ozzie-crawl
04-05-2010, 01:22 AM
you got me there :banana:
i just changed it,it was suppose to read "timing set at 15 deg"
Flying Scotsman
04-05-2010, 03:25 AM
The pond is a beauty. Was that Paddy's new phone?
Interesting run on the X637 and temperatures.
Douggie
ozzie-crawl
04-05-2010, 04:21 AM
no its of my phone,paddy lives about 1600 klm (1000 miles) from my place
