View Full Version : OSE Sport Packs
ReddyWatts
04-11-2007, 12:23 PM
Steven, I am sure that you have run tests on your sport packs that you sell (Racers edge 3600). What is the maximum continuous amperage that you recommend drawing from these cells, using deans connectors?
http://www.offshoreelectrics.com/products.php?cat=36
04-11-2007, 12:48 PM
I have run them on the bench with deans and 30amps with no problems. I will be using them more this spring with the supervees.
Steven, I have a DPR comming. I can run some tests on a set if ya want.
04-12-2007, 12:11 PM
There are more important things to do than test those packs. I wouldn't run them in much more than a sv.
ReddyWatts
04-12-2007, 12:24 PM
An SV draws from 40 - 50 continuous amps?
04-12-2007, 12:47 PM
Not the boat I tested. It was more on the average of 30 amps. I'm sure there were spikes of much higher. But not continuous at 50 amps with a stock prop.
