View Full Version : Anyone Run an Octura 1.25 prop???
Meniscus
03-31-2010, 03:42 PM
I'm wondering if anyone runs an Octura prop, model #1.25 at 31.75mm diameter?
If so, please provide feedback and your experience.
Thanks! :thumbup1:
Diegoboy
03-31-2010, 08:59 PM
I've never heard of that one.
egneg
04-01-2010, 05:42 AM
It has a 1.8 pitch - pretty high for the size.
Meniscus
04-01-2010, 02:52 PM
That's exactly why I'm looking at it and getting input! Don't worry Egneg, you'll see it when I get you to B/S :tongue_smilie: :thumbup1: :laugh: Thanks!
Diegoboy
04-01-2010, 02:56 PM
I guess no one has seen one in person...
NativePaul
04-01-2010, 11:10 PM
I take it this is a new prop not a Y531 that someone has converted the measurements from metric to imperial measurements on?
m4a1usr
04-02-2010, 12:05 AM
Nope. Octura has a decimal designation for this series. But I have not seen that size, my catalog only goes down to a 1.6". All the decimal series are 1.8 pitch ratio. That is not the same as pitch.
John
Meniscus
04-09-2010, 02:30 PM
Paul, is the Y531 available as metal? I haven't seen that and it doesn't appear in any of the Octura charts I've seen.
NativePaul
04-09-2010, 08:26 PM
Not available in metal that I know of, its just a side effect of growing up at a metric time in a traditionally imperial measuring country, mental conversions are second nature to me, never having heard of Octuras decimal range when Egneg said it was 1.8pitch and being named 1.25 I put 2 and 2 together and made 5, the Y531 which is very close to 1.25dia 1.8pitch
got any charts with the decimal series in?
Meniscus
04-09-2010, 10:31 PM
From what I saw from paper in a LHS, they read 1.25, 1.5, 1.6, 1.7, etc. which measures in inches.
The Y531 measures 31mm and the 5 indicates that it's 1.5 pitch.
Another example, X442 measures 42mm and 1.4 pitch.
I didn't see the pitch for the Octura model #1.25 on the sheet. I guess Egneg found it somewhere.
old guy
04-09-2010, 11:10 PM
I just got 2 off ebay to day and there is one left 1.25 1/8 bore
Old guy
NativePaul
04-10-2010, 03:49 AM
Ahh, I found them in the bottom octura prop chart on fastelectrics.com (http://www.fastelectrics.com/octuraprops.htm) , it looks like the are the 17xx series renamed, if so I know someone that swears by them for riggers, but they are not for my uses.
m4a1usr
04-10-2010, 06:27 PM
Looks like this.
John
http://i1009.photobucket.com/albums/af218/m4a1usr/DSCN2049.jpg
04-10-2010, 11:50 PM
These are among the oldest of the Octura prop series, designed before Tom changed to the current metric prop designations. They are high-lift props with modest blade area, and all have the 1.8 pitch ratio. They really are not too much like the 1700 series.
I used the 1.6 and 1.8 props years ago when they were available in metal. They are appropriate for hydros only, and most castings were very thick. The 1.25 was introduced several years ago, the rest are ancient, nearly 50 years old.
Meniscus
04-11-2010, 01:06 AM
Thanks Jay. I was thinking of trying one of these on my Batrax rigger. RPM's will be around 36,500's loaded (11.1 @ 3600kv). Any recommendations regarding taking some of the load off this prop, such as back cutting?
04-11-2010, 09:21 AM
I've only run it in its stock shape, but I suppose you could cut off some of the tongue. Be careful, the 1.25 doesn't have much blade area as it is. Set up right you're looking at 50s out of a rigger.
old guy
04-11-2010, 05:12 PM
I have 2 on the way from ebay and one will stay stalk the other one is going on the prop anvil for cupping. for $4.99 each I can play with them on my little rigger
Old Guy
Meniscus
04-20-2010, 04:26 PM
Did you get the props yet? Mine just came in.
old guy
04-20-2010, 05:00 PM
No not yet, it will be about a week more before the dog team gets here with them lol :bounce:
Old Guy
NativePaul
04-21-2010, 01:50 PM
So, wheres the pics Meniscus? Lets have a look at it.
Meniscus
04-21-2010, 02:39 PM
You got it. Give me a few since I'm at work.
Meniscus
04-21-2010, 02:59 PM
OK, here you go. The camera I have with me sucks to focus close, but I tried to capture the shape, pitch, and profile of the prop. I'll take some better pictures later if you'd like.
DELETED BLURRY PICTURES
For reference, those dark ebony block inlays on my desk measure 5mm.
Meniscus
04-21-2010, 03:15 PM
OK, let's try this again after beating the camera on the floor! J/K
25104 25105 25106
25107 25108
Meniscus
04-21-2010, 03:18 PM
One more:
25109
"Be careful what you ask for, you might get blurry pictures!"
