View Full Version : HIPPIE"S VS1 build
rchippie
03-26-2010, 07:19 PM
I figured i would start my own build thread . I fixed the gap in my hull . Today i made some sides for my battery & elctronic's box. They are just taped in place because i wanted some opinion's in case im doing something wrong. My plan is to cut out the back of the stock radio box to leave more room for adjusting the lipo . I hade to make my new sides go on top of the stock radio box because my turnigy lipo is taller the the stock box. Tell me what you think .
rchippie
03-30-2010, 07:36 PM
I re made my battery box . I made the sides from cut down bambo flooring & the back plate & braces are made from 1/4 plywood. I notched all the braces & the back plate. So they fit in between the sides as well as sitting on top . What do you think ?.
highndry
03-30-2010, 07:52 PM
Looking good Mike. Make sure everything is square as you go and test fit the cowl accordingly. Check with Jeff and Hugh along the way.
Your new Club showed well this past weekend against the big boys ( with the exception of OPC...) .
Mike
highndry
03-30-2010, 07:57 PM
I am no expert on tunnels, but upon further review, measure the distance from your box to the aft inside of the sponsons. It should be equal on both sides.
highndry
03-30-2010, 07:59 PM
Your box seems offset to the starboard side. Is that by design??
rchippie
03-30-2010, 08:08 PM
I just notcied that after you pointed it out. I measured it it is diffenitly off set. I wish i had noticed that before i cut the back of the radio box out.
Looking at it from the FR it measures 4.25 to the left sponson & 3 3/4 to the right sponson. I hope the hull is still usable .
DPeterson
03-30-2010, 08:41 PM
Mike
The VS1 is designed with the offset. It is one of the attributes that makes it a great turning tunnel. Some other tunnels have this as well.
Doug
rchippie
03-30-2010, 08:47 PM
Mike
Doug
Hi DOUG
I was not aware of that. That is great to hear since i have all ready cut the back of the stock box out for my conversion :laugh:. Thank you for letting me know .
ozzie-crawl
03-30-2010, 08:50 PM
funny that offset,i mentioned it a little while back and guys that own the vs1 hadnt noticed it
looking good with the box,just make sure the canopy fits over it well
rchippie
03-30-2010, 09:03 PM
Hi scott
I freaked out when i saw the offset :laugh:. Thank you for help you have been giving me . I all ready test fit the cowl. It's just a tad snug in the back . But a little sanding should take care of that . I ordered my hi-jack mount ysterday , & it's getting mailed tommorow . Did you drill the holes for you esc wires & linkage before you mounted radio box or after ?.
ozzie-crawl
03-30-2010, 09:13 PM
i glued the sides and top bits on first, made a servo mount and mounted that on,bolted lower leg on and ran steering rods,i then measured were the steering rods were and drilled the holes in the back plate,then the wire,water line holes, then glued the back plate in.
i drilled all holes in the back plate on the bench not when it was on the boat.
rchippie
03-31-2010, 11:45 PM
I will be using a ul-1 motor on 4s in my vs1 . Is the esc from the UL-1 okay to use as well or should i get a different one ?.
ozzie-crawl
04-01-2010, 04:05 AM
i have heard they ok guys are using them to race,think the later one may have a larger cap
and some add a cap to the original one, hope that makes sense
rchippie
04-01-2010, 05:36 PM
I was also thinking about getting two more turnigy marine 120's. Im pretty sure that would be enough esc :laugh:. One to use in the vs1 & one for a spare.
I also made my servo tray & esc mount.
rchippie
04-02-2010, 12:10 PM
MY hi-jack mount showed up today.
rchippie
04-12-2010, 12:12 AM
I got my outboard mounted. Thank's to jeff (obrien) for the help. I also got the back plate with all the pass thru's done as well.
bigwaveohs
04-12-2010, 12:26 AM
Did you cut through the top deck and styrofoam to lower the radio box electronics in the hull?
rchippie
04-12-2010, 12:31 AM
No i built it on top . I built mine pretty much the same as ozzie built his .
ozzie-crawl
04-12-2010, 06:24 AM
look good mate,just one thought were you have the steering rods you dont have much vertical adjustment,if you put the steel cleats on the servo side you can then use the pivot balls on the out side with a bolt to allow leg to move up and down and the rods stay in the same spot,i had a nut either side of pivot ball to allow adjustment but now i have it dialed in, i have a piece of tube one side and a nut they other,will take a pic tomorrow show what i mean
rchippie
04-12-2010, 03:33 PM
Scott
I figured out what you meant about the links. Here is what i made. Plus there is a couple of pics that show the amount of throw.
Also i all ready sealed the boat . But i need to put severasl coats of clear to protect it . Is it okay to us KRYLON for the clear coat, or is it better to use something else?.
rchippie
04-16-2010, 03:46 PM
I got some more work done.
rchippie
06-09-2010, 06:34 PM
I would like to take my VS1 out for it's maiden run tommorow. But i do not have any corrosion x to spray in the motor after the run . Is there anything else i could use or should i just wait untill i can get some corrosion x ?.
Rumdog
06-09-2010, 07:46 PM
WD-40 will work well too!
bigwaveohs
06-09-2010, 07:53 PM
WD-40 is fine...in fact I have rolled and sub'd mine a number of times and just blew any water out when I got home...UL-1 motor still runs fine...
rchippie
06-09-2010, 07:55 PM
Thats great. How much do i spray in the motor ?. Also should i spray denatured alcohol first or it that not needed ?.
Rumdog
06-09-2010, 08:06 PM
Spray it with a little WD-40 before you run and unless you flip, it'll pretty much bead off any spray. If you have compressed air, there isn't really a need for the alcohol but it cant really hrt.
rchippie
06-09-2010, 08:49 PM
How much is a little wd- 40, also do you put the little red tube all the way in the motor can or just spray around the holes on the end bell ?.
Rumdog
06-09-2010, 09:05 PM
Dont worry about over doing it. Give it a good soak if you want. Try to get it on everything you can.
rchippie
06-11-2010, 12:09 AM
First off i must the Ozzy-Crawl ( scott) & Obrien ( Jeff) for all there help. With out them i would still be working on my boat.
My VS1 had it's madien voyage today. It was totally AWSOME:laugh:. The boat was super stable & fast . Even the nitro guys were impressed, with how well it handled. Im using a UL-1 motor on 4s with a 42/55 grimracer prop.
ozzie-crawl
06-18-2010, 07:24 PM
great news,there a fun boat to drive.
i sold mine and the people who brought it just ran it at a state titles (same setup)
it had the least powerful motor but still got 3rd overall and a trophy
rchippie
07-02-2010, 02:23 PM
I finally got my cowling back from the painter.
Rumdog
07-02-2010, 04:29 PM
Sweet!!
BondoBrushless
07-02-2010, 05:39 PM
To bad Linc didn't paint some beans and wieners on it for you Mike ?
Linc did a nice job, looks great.
Got any video of this thing running ? Would like to see it go.
rchippie
07-02-2010, 06:50 PM
Here is a couple more pics, with some stickers i added.
LiPo Power
10-30-2011, 09:19 PM
wicked....
vanbisil
11-01-2011, 04:27 AM
Can you tell me were i can bye the hi jack mount ? Thanks Mike
