View Full Version : how long does it take to charge lipo batteries
speedfreak
03-25-2010, 12:00 PM
i got the Turnigy 5000 20c batteries and the turngiy charger but when i charge them i don't know how long and when they are done.....i'm not suppose to leave them on charge over night right....i left them charging for 1 to 2 hours is that enough....please help thanks
Jeff Wohlt
03-25-2010, 12:05 PM
It should shut off an give you an alarm when done. As long as you put your setting in right. Are you charging thru the balancer?
I use a Shultz so it just shuts off when done.
Brushless55
03-25-2010, 12:48 PM
It all depends on how many Mah you need to put back and at what amp rating you charge at...
If you put back 100% (5000mah) and charge at 5amps it will take 1 hour to charge..
If you only need 2500mah at 5amp charge then it will take 1/2 hour to charge..
03-25-2010, 01:34 PM
Man that would worry me. The charge rate must be pretty low. If not toss the charger asap.
speedfreak
03-25-2010, 02:01 PM
the charge is brand new though...along with the batteries....the only thing is that the chargers i bought were only $12 brand new from hobby king..
JimClark
03-25-2010, 02:12 PM
Is this what you bought?
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8247&Product_Name=Turnigy_2S_3S_Balance_Charger._Direct _110/240v_Input
Ask questions before you wast your money that charger will take years to charge 5000mah
you want at least a 50watt charger
speedfreak
03-25-2010, 02:41 PM
yeah that's the one....i bought 2 of those
Jeff Wohlt
03-25-2010, 02:45 PM
650 milliamp.... little over 1/2 amp. It is not bad for the cells but will take forever.
Get something that goes as least to 5 amp.
speedfreak
03-25-2010, 02:58 PM
with these charger how do i know when it's done....can i test the batteries with a voltage tester...if so what will it read....
Jeff Wohlt
03-25-2010, 03:03 PM
Does it have any light that turns red or green? If not who knows...not good for cells if it does not sense the charge and shut off.
You can put a Astro blinky between the balance connector and pack connector and it will tell you more.
speedfreak
03-25-2010, 03:07 PM
it does have three lights on it...... when i plug the battery in cell 1 has a red light....cell 2 has a red light and cell 3 has a green light.....what does that mean do you know?
JimClark
03-25-2010, 03:08 PM
didn't you get any directions on the charger?
speedfreak
03-25-2010, 03:09 PM
no i didn't...just came in a little box and that's it..
JimClark
03-25-2010, 03:10 PM
it will charge up to 3 cells each led is for one of the cells green means that the cell is done. How many cells is your battery?
Jim
speedfreak
03-25-2010, 03:13 PM
ummm i think 6...sorry i'm pretty new to this
Brushless55
All three lights will be green when its done..
takes about 7 1/2hrs for a 5000mah battery
JimClark
03-25-2010, 03:15 PM
Unless you are charging a 2s pack
JimClark
Give us a link to the battery you purchased
speedfreak
03-25-2010, 03:16 PM
damn....that's a long time.....well at least now i know when they'll be done....thanks
Brushless55
03-25-2010, 03:17 PM
2s or 3s 5000mah pack will still take the same amount of time at 0.640amps
speedfreak
03-25-2010, 03:18 PM
i don't know how to post the link but they are the turnigy 5000 20c batteries
JimClark
03-25-2010, 03:19 PM
Just talking about the amount of led's that will light
Brushless55
03-25-2010, 03:23 PM
yes.. :iagree:
Brushless55
03-25-2010, 03:24 PM
those are great batteries!
JimClark
03-25-2010, 03:32 PM
Doesn't look like Norm over on RR is a big fan of Turnigy
http://www.rumrunnerracing.com/feforums/showthread.php?t=30223
Diesel6401
03-25-2010, 03:42 PM
hmmmmm, I just bought 4 2s turnigy lipos and got them in the mail a few days ago. I Haven't even opened them yet. Makes me wanna run home and check some numbers.
Brushless55
03-25-2010, 03:51 PM
I have 8 Turningy packs and only one issue with them..
but lots of power!
egneg
03-25-2010, 03:53 PM
I have a pair of 4S/30C/5000mah packs that I am very happy with and plan on getting 2 more with higher C ratings.
Diesel6401
03-25-2010, 04:02 PM
I have 8 Turningy packs and only one issue with them..but lots of power!
What was the problem?
Brushless55
03-25-2010, 06:09 PM
One of my 3s packs had a bad connection to one of the cells
Diesel6401
03-25-2010, 06:11 PM
Did you repair it or send it back?
Brushless55
03-25-2010, 06:12 PM
I'm going to repair it..
sending it back could take forever
Diesel6401
03-25-2010, 07:14 PM
How long ago did you receive the battery? I'm just curious.
speedfreak
03-25-2010, 09:42 PM
well i charged them for about 4 hours today. in the begining when i pluged them in they were "cell 1 red, cell 2 red, and cell 3 green." but after 4 hours of charging all three lights were red. i guess well see tomorrow if thet are charged, if so it's about 5 hours to charge these batteries with these little chargers that i got for $12 a piece. thanks guys.
wizard122
03-26-2010, 05:31 PM
Thats Great I just want to show you what I use all set up 2 Chargers 1 power supply 4 packs be very carefully when charging multi pack check my threads I have photos :bounce:
Diesel6401
03-26-2010, 05:52 PM
I checked all my batteries last night and all cells were good. All voltage was within 3.7-3.85 volts. One cell was below that at 3.5 volts. Also the 2 40c's already came wired with 5.5 bullets which made me happy, 4 less plugs to solder and potentially burn my fingers as always lol. Hopefully we'll see how they run monday tuesday or wednesday.
wizard122
03-26-2010, 06:28 PM
Cool I was reading alot of post today home sick. have you checked any of the stuff flat sponson's block sanding stuff like that?
Diesel6401
03-26-2010, 06:34 PM
Not following buddy :confused2:
(get better, sadly its suppose to rain sunday and and maybe monday.)
wizard122
03-26-2010, 06:38 PM
Blueprinting hull make shure everything is flat and corners are sharp stuuf like that.
wizard122
03-26-2010, 06:40 PM
this is what I mean
http://forums.offshoreelectrics.com/showpost.php?p=70349&postcount=31
Diesel6401
03-26-2010, 06:49 PM
O I got you now. No I haven't attepemt any of that yet. I read it before and I also read the aoa one detox made. Both threads are GREAT, but Im kinda scared too. I ordered the new gps and I'm going see the configurations stand up with speeds. I also got 2 4s's im going to run in parallel, the xtra weight may work better. I think im going to re-read the thread you posted.
