View Full Version : some tech info needed on a new CAT project
omega
03-23-2010, 09:34 PM
Hello Guys
I am new to electric boats (racing gasoline boats at moment). I have a 30 inch Aeromarine Cat Hull that I am setting up with a 6s Feibao 580 brushless motor, 180Amp Turnigy Marine ESC.
The shaft will be 3/16 for a 1/8 prop.
Can you guys suggest a good propeller diameter for this set up?
Cheers
Andre
ozzie-crawl
03-23-2010, 11:34 PM
what hull and what kv motor
omega
03-24-2010, 12:01 AM
Katamaran from Aeromarine, 30 Inch long, Feibao 580 9L, 1,426 RPM per Volt... think is about 1450KV ?
BakedMopar
03-24-2010, 12:22 AM
I dont think you would want to run a 1/8" prop. At least 3/16".
ozzie-crawl
03-24-2010, 12:26 AM
okay i am taking it that its a mean machine, imo its a bit of over kill
a 540 xl would be a better choice.or a neu motor on 4s
other than that try a y537/3 prop from octura, you will want a .187 flex and 3/16 shaft
ozzie-crawl
03-24-2010, 12:28 AM
read threw this lots of good info http://www.offshoreelectrics.com/forums/showthread.php?t=751
omega
03-24-2010, 01:15 AM
thanks mate, been given the feibao as a suggestion from the guys at offshoreelecrtics.... you think drivable with a 6s 3850 TP packs? more for top end rather than competitive racing.... not much going on around here (Singapore) for electric... lots of gassers...
ozzie-crawl
03-24-2010, 02:05 AM
if you havent brought the motor yet and want to go 6s a neu 1515 1.5y would be a very good setup.
a decent 4s setup like a neu 1515 1y 2200kv on 4s 1p 5000 would be good as well.
the feigao 580 is a heavier motor and less efficient than the neu
the neu is $90 more expensive but well worth it.
o.s.e also has the 1415 1.5y in stock and is only $50 more than the feigao this to would make a very nice 6s motor
omega
03-24-2010, 02:13 AM
unfortunately i bought it motor the other day in hong kong... for a 100 USD so good price i guess? i get a feeling that i should have worked on a 4S set up... do you see any major set backs if i go with the big motor and 6S?
ozzie-crawl
03-24-2010, 02:20 AM
the motor is fairly heavy but will produce more than enough power,i was just trying to give what i thought was better options.
that motor on 6s will still be a very strong setup,imo a little heavy but if pushing for high speed the extra weight may help.
one thing if your pushing for speed i would get on of these hatches, much easier to tape down and less likely to come of in a flip http://www.offshoreelectrics.com/proddetail.php?prod=ffrb-mm-cowl&cat=123
omega
03-24-2010, 02:30 AM
thanks man, great advise... should be a fun boat... is a older aeromarine hull , shoe box design.... i will keep you posted here how this all ends up
justintime2w8
03-24-2010, 10:37 PM
Shoe box is great as long as you can keep the lid on the box:-)
