View Full Version : Run Time
Crazzymugen
03-12-2010, 07:28 AM
Gday guy's Just want to no how long should i get out of 2 5000 zippy 30c Battery's At the moment i am getting 7 minutes.
Prop being used is a Grim L40x57
Cheer's Dave..
03-12-2010, 07:35 AM
Seven minutes until what, the LVC? You are pulling under 40 amps average - pretty low. I'd say you are getting plenty of run time; a lot depends on how you run: how much WOT, how much acceleration, etc.
Capt. Crash
03-13-2010, 06:49 AM
7 min. sounds about right...I run 3 ea. 2.5 min. runs at full tilt on 5250 30c and am done with those packs for the day.
Crash
Crazzymugen
03-13-2010, 10:11 AM
Thank's for the reply Guy's
Look's like im going to need 6 more lipo's
7 min's not enough run time .
Just to let you guy'e no that here in Australia you can not get the ul-1
I Went to the Australian toy fair yesterday were us retailers go all i can get is the supervee 27 some thing wrong there.
Check out these Boats . www.fs-racingart.com
Brushless55
03-13-2010, 10:52 AM
7 min of run time is very good for a UL-1
how many Mah are you putting back after 7min?
I usualy only run 5 1/2min max with my UL-1 on my Turnigy 5000mah 30C packs
Crazzymugen
03-13-2010, 06:29 PM
The Pack's take 5150 mah after charging .Zippy 5000 30c
These pack's have been great.
egneg
03-13-2010, 07:05 PM
That time is great ... I only get 2 - 3 minutes until I crash & burn.
Crazzymugen
03-13-2010, 08:21 PM
Look's like im haveing good luck then.
Did u guy's check out the web site link www.fs-racingart.com
Brushless55
03-13-2010, 09:00 PM
You could possibly hurt the packs running them down 100%
Crazzymugen
03-14-2010, 06:00 AM
I run the ul-1 until the 12 volt stutter warning comes on.
As for the pack's She'll be right mate.
The charger i use is a Swallow Advance.
Brushless55
03-14-2010, 07:52 PM
well the UL-1 esc goes way low for a cutoff
and running packs beyond 100% will shorten their life span
but if that's the way you want to run, run it..
