View Full Version : turnigy esc ?
rchippie
03-07-2010, 03:23 PM
I have this esc http://hobbycity.com/hobbyking/store/uh_viewitem.asp?idproduct=8946. I would like to use this programming box .http://hobbycity.com/hobbyking/store/uh_viewitem.asp?idproduct=7187 Does anyone else use this, if so do you have to use the faceplate from the zip file ?. thank's
westbeach
03-07-2010, 03:40 PM
edit.
TRUCKPULL
03-07-2010, 05:49 PM
I have used that Programmer on a Marine 180 with the use of the faceplate from the zip file.
Larry
egneg
03-07-2010, 07:13 PM
This is the one I use ...
http://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=2169&Product_Name=TURNIGY_BESC_Programming_Card
ezhitz
03-07-2010, 07:20 PM
I also used the one you showed with the downloaded faceplate for boats on my 120 esc.
sailr
03-07-2010, 07:51 PM
You have to be careful. Those two program cards are NOT interchangeable. The Turnigy you refer to is made by Hobbywing and uses the box. The other one somebody showed is for their aircraft esc's only. I have verified that with the factory.
You have to use the BOAT faceplate in the zip file. The Boat esc's program differently than Cars, etc.
rchippie
03-08-2010, 01:07 PM
Thank's JIM. :smile:
rchippie
03-13-2010, 03:57 PM
Im installing my turnigy 120 marine esc in my rigger. It has a little magnet near the reciver plug that the wire is looping thru. Are you guys leaving the magnet on or taking it off ?.
Make-a-Wake
03-13-2010, 04:11 PM
I took mine off.........it didnt change anything.............
sailr
03-13-2010, 04:33 PM
LEAVE IT ON THERE! It's a ferrous iron ring. It reduces glitching and interference to your radio! It's on there for a reason. Otherwise why would the manufacturer put it there?
Drag Boat Bob
03-13-2010, 04:34 PM
I believe this is a choke. A sort of 'filter' between the ESC and rx.
sailr
03-13-2010, 04:36 PM
EXACTLY! Some receivers are ultra sensitive. If you took yours off and it didn't change anything, then your receiver tolerates it just fine. The manufacturer of that ESC is very conscientous and quality oriented...more than any other I have ever known.
Drag Boat Bob
03-13-2010, 04:43 PM
For a better understanding of its use, Google it (Electrical Choke). They are used in almost all electrical circuitry i.e. stereo components/TV's/computers etc.
rchippie
03-13-2010, 05:11 PM
Thank's for the repliy's. This is the only one my esc's that has ever had one. So that why i asked . I will leave it on .
Make-a-Wake
03-13-2010, 07:44 PM
I took the "risk" and took mine off as i said above...............but im using 2.4 ghz..........maybe thats why i have no issues.............
