View Full Version : Darin's 28" Woodstuff
Sponsorship Change!
Darin, couldn't help funnin with ya buddy!
All the best,
Ray
Doug Smock
03-04-2010, 06:22 PM
The boat looks great Ray!!
Thank you Sir! But, Darin did all the hard work.
Ray
Cat-Boi
03-04-2010, 06:32 PM
very nice there ray!
rchippie
03-04-2010, 06:33 PM
That boat looks so nice with the natural color wood .:smile:
Darin Jordan
03-04-2010, 07:30 PM
That's a Shame! ;)
Hahahaha... Looks really nice. Those a slower decals, but at least they look good... :D
Have FUN!!
bonewar
03-04-2010, 09:08 PM
Very nice Ray,
I love the look of these boats , specially the exposed wood spoonsons.
Good job!
Bonewar :rockon2:
I always did like the looks of a finished wood boat!!! Superb work there Darin.
Chuck E Cheese
03-09-2010, 02:27 PM
can you post pics of the radio box set-up? are you guys using ul1 esc's as well or does the tunnel draw too many amps?
Darin Jordan
03-09-2010, 03:41 PM
I ran the stock 45-amp ProBoat ESC for two seasons... I can tell you from EagleTree data that the amp draw is CONSIDERBLY more than you'd think... 60+ continuous on my setup, with high periods approaching 100... ESC eventually just stopped working... no smoke, or anything... just stopped... literally... 2-laps in.. no more go...
Chuck E Cheese
03-09-2010, 04:02 PM
roger that, you were using the proboat motor too werent you? i havent had any issues with the stock ul-1 stuuff in my rigger and that turns a 48mm prop, but that is a rigger....
what would you recomend? what do you use now?
Darin Jordan
03-09-2010, 04:06 PM
I still use the ProBoat motor, but it's not easy to do that and really keep up with the fastest UL-1 powered boats... It can be done, but you need to drive well and really have a good prop...
Tough to describe my prop... it started life as an X645... but it's only 41.6mm now, and is completely tweaked... Still room for improvement, I'm sure... but on a small light setup, it works...
I'm thinking the BJ26 setup might work better on a little bigger boat that can handle more prop... the WoodStuff started to get a little dicey when I went too big... Backed off on the speed to keep the handling.
Chuck E Cheese
03-09-2010, 04:14 PM
i was thinking of a vission or wood 28 with the ul-1 set. i have a super-v/ts2 right now and am looking for something that fits my collection better. i like the sv but the ul-1 motor impressed me so much in a jae rigger i just cant see why i dont have a tunnel with it. i considered a hot rod but think if i can get a spec boat doing high 30's low 40's that is what i need. what kind of speed are you getting out of the bj?
Darin Jordan
03-09-2010, 04:17 PM
Aim higher... My WoodStuff 28 with the BJ setup in it races in the upper 40's... 47-49mph.... Average speeds around 38mph for the race... with moments of glory as high as 53mph... though I don't like the way the boat drives with that particular prop...
Chuck E Cheese
03-09-2010, 04:20 PM
wow..... i was just thinking that my 21 tunnels get mid 40's so that was the mark but aparently the bar is going up...
Darin Jordan
03-09-2010, 04:22 PM
Here is a data set from one of my races last season. This was my standard race setup, more for handling than all-out speed...
Chuck E Cheese
03-09-2010, 04:25 PM
verry nice!
Darin Jordan
03-09-2010, 04:36 PM
verry nice!
Just keep in mind... that, while this is with the stock ProBoat 45-amp ESC... I KNEW that I was working on borrowed time with that setup... The motor is fine.. but the ESC eventually got tired... Gave me a couple of seasons, however, including our clubs OPC Tunnel High-Points... :thumbup1:
By the way... the speed was measured using an airspeed sensor onboard with the EagleTree... it's NOT GPS...
