View Full Version : Help please !!
BRIAN
02-18-2010, 05:13 PM
B:help:his question has probably been asked 8million times but i cant use the search function right now. I have a traxxas villian thats all stock i want to put lipos in it and different props maybe modified motors but im having a info overload.Stock motors or modidfieds what props do i need is 8000mah 2 cells too much and what pinions should i use any help would be great i usually stick to the dirt but i drove a friends proboat and i was hooked THANK YOU !! brian
Jeff Wohlt
02-18-2010, 11:17 PM
I would try the lipos first with 442 props. Move to BL when you can. Those are big cells and you really do not need that large. I would run a couple of 4000/5000 packs in the 30C range...smaller and lighter and you are not loading them much anyway.
Your stock hardware is the limit on power.
BRIAN
02-18-2010, 11:32 PM
Im gonna sound really stupid but what is BL ??
eboat
02-18-2010, 11:46 PM
BL stands for brushless motor
BRIAN
02-18-2010, 11:53 PM
thank you eboat and btw jeff i would have to get two esc's because its dual motors and dual batteries i wish someone made a single motor conversion for villian maybe ill just seal up the hull and go with one stuff tube cure all my problems with room and adjustability
wakeboardfusion
02-19-2010, 01:00 AM
I would go with single motor direct drive. Its not too hard to seal up the hull, just get some abs and epoxy. Doesnt need to be perfect, just cut to fit and epoxy in.
BRIAN
02-19-2010, 08:16 AM
single drive brings up so many more questions were to put the drive shaft tube what angle etc etc
BILL OXIDEAN
02-19-2010, 08:26 AM
You can upgrade the power system while using the remaining hardware, one suggestion is Boca Bearings yellow seal bearings in the outdrive i believe that one takes 5x11. The yellow seal literally never go gritty on you.i've run a set for 3 seasons with zero failure.
BRIAN
02-19-2010, 08:37 AM
i seen a write up that traxxas actually did on running bearings im gonna do that they say to use an 11/32 brass tube and 4x8mm flanged bearings but it said to use stainless steel bearings that noone in the world makes but if bill says the boca bearings yellow seal is water friendly ill go with that thanks guys !!!
