View Full Version : 1/8 Shaft Carbon props
boater76
02-16-2010, 06:18 PM
Do any online stores have carbon props for 1/8" shafts? I need smaller sizes for my mini hydro. My pocket can afford metal ones and then go and have to buy a balancer and balance and sharpen them.
Diesel6401
02-16-2010, 07:30 PM
If you use this: http://www.offshoreelectrics.com/proddetail.php?prod=ose-1035 you can have a more selection of props. Also the Miss Vegas and Miss Elam use 1/8 props so you may be able to order the stock or recommended hop-up prop for those boats depending on which dia your looking for. Hopefully this helps.
ray schrauwen
02-19-2010, 12:22 AM
To use threaded Graupner carbon prop just drill out through the thread and plastic, with a 7/64 drill bit.
You can then thread on the prop onto a 1/8" threaded stubb shaft.
Works better if you run a 5-40 tap through it first.
I drill them out by hand on a piece of wood, With a new drill bit it seems to always go true.
Steve V. OSE taught me this.
