View Full Version : Upgrade motors for the King of Shaves.
02-15-2010, 09:49 AM
I have some feigao 380 XL motors on the way for the dual cat. Should be a big improvement.
forescott
02-28-2010, 01:09 AM
Any new news on when we might see some of these? Looking for the 380 8xl.
02-28-2010, 07:35 PM
They are coming with my present Feigao order, About 2 to 3 weeks.
bill1473
03-01-2010, 02:38 AM
Did you order them directly or or through a local distributer?
03-01-2010, 07:12 AM
We are the US distributor for Feigao motors.
bill1473
03-01-2010, 05:25 PM
what motor would i get out of the 5 380L? And could the esc handle 4 or 5s. Im using dynomite 3s 5300 lipos now , but i plan to put them in my bj26 and get new ones for my ekos. I want the best and safest motor esc combo
03-01-2010, 07:13 PM
I've had one customer running 10L motors. But I would suggest waiting for the xl series.
bill1473
03-02-2010, 11:27 PM
Just fried the right motor. Definetly need new ones now asap! Would you happen to know what order number and ill order them. Tried to put the vid on youtube but cant publish it. Ill keep tryin.just a short vid. Got 37 mph with gps. Had the trims up, 3s lipo 447 props , should have listened. You guys also have b/s props counter rotating bigger than 36 mill?
forescott
03-03-2010, 12:02 AM
Those props are waaay too big. I get 36mph on venoms 36mm pro machined props. The little 380 motors dont have enough torque to spin a 47mm prop. They will spin, but the rpm is significantly reduced and the motors get extremely hot trying to push those big wheels. You're not gonna get much more speed then mid 30's on 3s. If you want more speed you,re gonna have to swap out the motors for something with higher quality and bump up to 4s. Take your time. Happy boating!
forescott
03-03-2010, 12:04 AM
Steven, any plans on offering a longer version of the 380 sized water jacket for the feigao?:thumbup1:
03-03-2010, 11:26 AM
Yup :thumbup1:
bill1473
03-03-2010, 11:33 AM
I just ordered the fiego 380 l motors, water jackets, water outlets and xtra tubing. I took the water outlets off the motors and put them on the motor mounts. I have 4 ektra brass tubes that ill mount on back so motor, mount, and esc each have there own intakes and outlet. Ant ideas on who makes the best and smallest 4s lipos and B/S props besides venom. Allready have a set of 36 mill machined props. Hope the order comes in asap.
bill1473
03-03-2010, 11:35 AM
Steve do you work for offshore electrics. Is so can i give you a call about my order that i placed lastnite or direct me to someone please
03-03-2010, 11:39 AM
Wednesday is my day off sort of, I'm not in the office, but orders still ship. The quickest way is the contact page from the OSE website. A FYI, most all the orders placed yesterday have already been shipped this morning.
forescott
03-03-2010, 05:07 PM
Not much out there as far as counter rotating props are concerned. The 36mm venoms you have are great props. I'm not posotive but check ose's website details on the feigao L-sized motors. I think they are only good up to 3s lipo. Thats why I'm waiting for the XL's. They are rated for 4s.:thumbup:
bill1473
03-03-2010, 07:10 PM
Ill have to buy them next. But have been lookin for lipos. Found a few 4s 5000 models but what does 25c or 30 c mean. Do i want the highest c and millamp rating i can fit. My charger can only charge up to 5000 mill. The c rating is what gets me and if my esc can handle it.
bill1473
03-03-2010, 07:12 PM
I have 3 to choose from. Thunderpower, neu , and maxamps
forescott
03-03-2010, 09:04 PM
Check out hobbyking.com and their turnigy lipos. They are inexpensive and a lot of guys on the forum use them including myself and they work great! Go for the 30c rating, no less than 20c.
bill1473
03-03-2010, 09:18 PM
K thanks
bill1473
03-11-2010, 11:43 AM
Steve, did you get the fiego xxl or xl motors in yet?if not when do you expect them ?
bill1473
03-14-2010, 07:34 PM
I just got my 4s lipos in and im going to reprogram the esc. I also have my 3s lipos. Would i have to reprogram the esc every time if i want to run the 3s lipos?
forescott
03-15-2010, 12:36 AM
No, look in your manual. There is a setting for "auto calculate"
Jeff Wohlt
03-15-2010, 12:46 AM
Up the power and you may consider upping the drive train. Any way to pull the teflon out and run a 150 shaft in them? I know a 150 cable will be too big for the 4mm shaft...wonder if those can be upgraded>.?
I am waiting on RH cable and I will be offering cables to fit the factory stuff. The struts may be able to have the bushing removed and upgraded to 3/16" shafts. I just finished some 4mm shaft stingers doing this for a guy.
forescott
04-01-2010, 07:15 PM
Feigao 380Xl motors and cooling cans are in stock at OSE! Get em while you can!! :banana:
Jeff Wohlt
04-01-2010, 08:07 PM
Get my new couplers and 130 cable system with the same shaft as stock and then you will have something to handle the power and torque. You will need it.
04-01-2010, 08:28 PM
Once you guys decide on the right one I will get more. I have 5 more of the 9xl motors on order. I thought I ordered 10, but only ordered 5. I figure either that or the 8xl will be the ticket.
So you guys figured 8xl is the one to go for a 3s and 9xl for a 4s?
You would get more speed out of a 9xl on a 4s right?
What props would you go with x442 and x442r?
forescott
04-13-2010, 01:24 AM
9xl's got me 55.2mph on 4s with 40mm carbon props. 442's L&R are what I'm gonna try next! :buttrock:
55,2 that is cool. How many Amps did it do this at?
skater368
04-13-2010, 09:52 AM
i need 2 9xl's. are they in? i cant find them on the site
http://www.offshoreelectrics.com/proddetail.php?prod=fei-380-xL&cat=116
looks like 9xl is not in stock, just 8 and 10.
What about 7xl (3,357kv) on 3s, or will it be just too much for the motor to handle anything bigger then 32 mm props and running 8xl with 4s will be just more efficient and faster?
C-Mac
04-15-2010, 11:36 AM
Would the 9XL's be fine on 120A ESC's?
annmitchael
04-15-2010, 12:44 PM
show more progressive picture
forescott
04-15-2010, 08:45 PM
Thats what I am using on the 9xl's An 80-90amp esc should work fine too, but hobbyking has the turnigy 120's for $49 each. I think the general rule is motor amp rating should be 80% of speed control rating. So a motor that pulls a constant 80amps should have a controller that has a constant 100 amp rating. If I remember correctly the 9xl has a constant rating of around 60amps, putting the required esc amp rating at about 75amps. The stock 60-amp controllers may work, but you would be pushing the limits, especially if you start running larger than stock props.
electric
04-16-2010, 05:27 PM
Watching the thread here and wondering whether I should just buy a hull fo 132.00 and just start from that point. Might be able to round up all the hardware myself and end up with a better boat for about the same money?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXXSM5&P=Z
Boat is $500. Hardware in the boats is not that good, so better off buy the hull and build.
The space is a bit tight to work in.
Just need to see what drive hardware fits for the prop unless you can get venom as well.
Just went through parts on the tower, looks like it would be $260 in venom part + electronics.
So two 120 ESC, $120, two 540 motors with jackets $170 + motor mounts $50 + servo $25 would be $365 total $625 + $100 to radio so $725 + $65 for two balanced props is $790 Venom stock is $500 but this would be faster setup.
electric
04-16-2010, 09:02 PM
Chuckle, Thanks Vasy, you saved me a night of doing what you just did!! However, in my case, I already have, the radio the servo and receiver. I have a bunch of other hardware laying around, so I need to round up what I have already and see what is missing. I believe I can do much better on the motors(china). You are probably correct on the ESC.
I have alot of sv27 hardware and another rudder from an old boat that might work etc. So my cost might just be Motors, ESC, linkage, and drives. Come to think of it, I have one esc that will work. The joy of being in this hobby awhile is you get a REALLY big parts bin!!
BILL OXIDEAN
04-17-2010, 05:36 PM
Jeff, do you have an aluminum coupler that fits without having to cut the stuffing tube down?
Jeff Wohlt
04-17-2010, 08:22 PM
Yep...
Wakesurf1
04-26-2010, 12:32 AM
I need two Feigao 380 9xl's, water jackets and couplers. Does anyone know when they'll be back in stock or where else I can pick them up? just fried one of my stock motors. Thanks guys!
forescott
04-26-2010, 01:25 AM
As far as I know offshore electrics is the only place to get the 380XL's. You wont be dissapointed with the 9XL!!
04-26-2010, 12:05 PM
I should have more 380xl motors in about 2 weeks.
