View Full Version : ESC Turn Limit???
illz302
02-13-2010, 11:04 PM
Ok guys I have a spare 15t motor laying around still new in its package and I wonder is it possible to run this with the stock esc? What is the esc turn limit?:confused2:
Diesel6401
02-13-2010, 11:39 PM
I highly suggest new esc, stock is garbage. I burned 2 of them up. To answer your question it is listed at 27t.
illz302
02-13-2010, 11:42 PM
ok thanks!
Brushless55
02-14-2010, 12:58 PM
I think the weak link on this boat is the esc..
illz302
02-15-2010, 12:45 AM
Yea UPDATE I ran this new boat today at the local lake and about halfway through my 4000mah 2s 25C lipo the esc gave out. So when I got home I realized wait a minute I have all the electronics out of my Apache 24 which is under construction right now so I did some soldering and moving of things and came up with this.......
http://i553.photobucket.com/albums/jj378/illz302/RC/Sea/CIMG1423.jpg
It should do for now in a few weeks I am going to get a VXL3S system from my friend. And i will run that with a better cooling jacket on the motor with a 3s and see where it goes from there!
Brushless55
02-15-2010, 12:47 AM
Those are much better of an esc
illz302
02-15-2010, 01:13 AM
yea i think im going to run a cheapo 19t bb mod motor from my lhs for now im actually thinking now that the vxl will do much better in the apache so ill use the rio for rescue purposes LOL not that its not loved!
Diesel6401
02-15-2010, 11:16 AM
Told you the esc sux lol...
illz302
02-15-2010, 11:18 AM
LOL yea i know thanks diesel the apache esc thats in there now is running great even with my 2s with no problems go proboat haha j/k
Diesel6401
I think that may be to much kv for a apache. VXL motor is 3500kv correct? Anything above 30mh on a apache I read the hull cant handle. Good luck though, I would love to see if you can get it working right :rockon2:
Diesel6401
02-15-2010, 12:04 PM
Cool, glad it is working well for you. After I blew my second one I bought a waterproofed xl-5. A little more $$$ for a brushed esc but sometimes I don't mind paying for peace of mind.
illz302
02-15-2010, 02:40 PM
Diesel here is one on a 3600kv motor and 3s everything else besides the esc of course is stock and it seems to be fine to me. Now keep in mind i understand it will need to slow down some before turning sharply but it seems to handle ok here......
http://www.youtube.com/watch?v=AR8PRtPw-Bc&NR=1
Brushless55
02-15-2010, 03:44 PM
You sure that's a 3600kv motor on 3s and a 42mm prop?
it is faster than stock but not 40k rpm. :confused1:
Brushless55
What motor are you running with the Traxxas esc?
illz302
02-16-2010, 10:36 AM
the vxl motor with a good water cooling jacket.
Brushless55
02-16-2010, 01:51 PM
that video does not look like a VXL powered Rio ep on 3s.. :confused2:
illz302
02-16-2010, 03:04 PM
it isnt but if the kv is the same than whats the difference?
Diesel6401
02-16-2010, 09:09 PM
I was running a Titan 12t on a 7cell nimh. Hit 19mph with stock prop. I put the stock 550 back in though because I converted it to a rescue boat and needed lower rpm higher torque the stock motor had for pushing a stalled/flipped boat.
Brushless55
02-17-2010, 04:21 PM
You said it was a VXL motor, now its not.. :confused2:
a VXL motor on 3s is a monster!
almost 40,000rpm and on the stock 42mm prop tha Rio ep would fly! :rockon2:
illz302
02-17-2010, 04:24 PM
No i did not say the guy in the video was using a vxl system i said i am using the vxl system in mine and i was showing the video becuase it had a brushless system in it that had basicly the same kv rating and cell count
Brushless55
02-17-2010, 04:31 PM
read post #13 and on..
I don't think the video you posted has a 3600kv motor on 3s, that would be right at 40k rpm and on the stock 42mm prop it would move out real fast
he is posibly using a 2s pack :thumbup1:
illz302
02-17-2010, 04:37 PM
im not saying that you said you were confused i was just clarifying for you 55. I dunno either that or its like a 15-20c 3s just a guess on my part. anyways ill be ordering 2s and 3s so i can try both.
Brushless55
02-17-2010, 04:42 PM
Clarifying, I'm not sure what that means?
I was asking about the video not your setup, because the video looks slow for a 3600kv motor on 3s with a 42mm prop.
the video you posted that I was talking about looks more like he may have used a 2s pack or even a 6cell nimh pack with that motor and prop :thumbup1:
illz302
02-19-2010, 01:15 PM
hmmm interesting i will have to try the 2s first then and if im feeliing lucky and heat is low then ill try the 3s
illz302
02-26-2010, 04:35 PM
Well I ran it with the current setup with the apache esc and the apache motor and the motor died within two runs on the 2s lipo. So then I swapped in a venom 15t motor I had laying around that was used once before for a run to test in the apache and within one run the apache esc died. Thats just my luck:doh:
Brushless55
02-26-2010, 04:38 PM
the venom 15t sucks some amps, and they don't put down much power..
go brushless bro!
illz302
02-26-2010, 04:41 PM
I am now considering I used all my leftover electronics up in this boat:olleyes:
Just have to wait for more money now :thumbup1:
Brushless55
02-26-2010, 04:51 PM
bummer!
Diesel6401
02-26-2010, 06:08 PM
My buddy blew his apache motor after only about 5 runs... SUX!!!
