View Full Version : Turnigy Monster 2000 help
RandyatBBY
01-22-2010, 08:33 PM
While I have been building my 1/8 Pro Boat I have been working on a friends boat that will be running in the district. It is a Dumas Circus Circus 1/8 wood kit, with my HWD. the KB motor, a Turinegy Monster 2000 esc on 8S2P Turinegy cells.
I just tried out the ESC and I can not get it to reverse. I reversed the servo in the transmitter in throttle. position to reverse. Nothing happened. I had done the initial start up in reverse. I tried to shut off and re calibrated it nothing changed. I still comes on when you break it.
Pictures of the boat and parts thought you all would like to see.
http://img228.imageshack.us/img228/8746/img2347k.jpg
http://img718.imageshack.us/img718/9835/img2350.jpg
http://img109.imageshack.us/img109/4251/img2351i.jpg (http://img109.imageshack.us/i/img2351i.jpg/)
Flying Scotsman
01-22-2010, 08:50 PM
Randy have you programed it with the specific program card for that ESC
Douggie
RandyatBBY
01-22-2010, 08:53 PM
Douggie
No, I do not have one.
m4a1usr
01-22-2010, 09:03 PM
I'm trying to sort the sequence out here Randy. Your trying to reverse the throttle setting on the ESC? Instead of just switching 2 motor wires? That speedo does not have a reverse setting if you are seeking a forward and reverse setting like some do. I know I'm not getting it to really be of any help.
John
RandyatBBY
01-22-2010, 09:07 PM
No, not the diredtion of the motor. The direction of the throttle, from full on to full break it works correctly.
I want it to go from netural to full on normal. I think I need a Pisitx to start off with after wright ing this.
RandyatBBY
01-22-2010, 09:11 PM
I just installed and RC Hydros Pistix and it works correctly! good news. Now I have to get some more for my friend.
Mel279
01-23-2010, 03:01 PM
[/QUOTE]
hey Randy
Is that a watercooled outrunner motor?its look so big:w00t:
RandyatBBY
01-23-2010, 07:54 PM
hey Randy
Is that a watercooled outrunner motor?its look so big:w00t:[/QUOTE]
Yes it is, I have two to sell and one in my Pro Boat.
NativePaul
01-23-2010, 09:14 PM
How do you keep it watertight with the strut on the inside? any close up pictures, i had assumed a fixed strut attached to the bottom, but that looks like a regular adjustable strut just attached to the inside of the transom rather than the outside.
RandyatBBY
01-23-2010, 09:18 PM
RTV sylcon on both sides of the bottom and deck tape on the top check out my Pro Boat build it has pictures.
Adrianli
02-04-2010, 07:24 PM
Hi Randy,
I am interested in this motor also. May I know the KV of this motor??? It looks similar to the one Littlescreamers are selling.
I am running a NEU 2215 2Y motor with 750kv wif a Octura X455 prop and 10S lipo.
What would you suggest the prop size to go with this motor?
RandyatBBY
02-04-2010, 08:27 PM
Hi Randy,
What would you suggest the prop size to go with this motor?Yes I am a little screamer dealer. This motor has 650Kv I have two in stock, about ready to test in a 1/8 Pro Boat.
slyman
09-12-2010, 04:43 PM
What ESC did you use and will it handle 6s?
Jesse J
09-13-2010, 10:48 AM
thread here seems to be off topic of OP, but I didn't want to start another thread on this ESC.
Does anybody know if it can be programmed with the TX? I have an order on programming card, but out of stock...
Anybody have a digital set of instructions or know what the default settings are?
thanks
J
Flying Scotsman
09-13-2010, 11:30 AM
Jesse, Yes, but you do need a Pistix. I will hunt and see if I have the instructions and will email them to you, if you wish
Douggie
Jesse J
09-13-2010, 11:37 AM
That would be great Douggie, thanks. geohead73@hotmail.com
I was told by Jason that my Spektrum 2.0 should be able to handle the pistix problem... he said he got his to overcome the issue.
Flying Scotsman
09-13-2010, 11:41 AM
I have found the instructions and will email them in pdf format within 5 hours
Douggie
Jesse J
09-13-2010, 11:59 AM
You rock. take your time, the ESC isn't even here yet - main reason was to see if I needed to do any programming or if it was set to what I will be using. I appreciate the effort!
