View Full Version : Bodywork on sv27 hull?
whiplash
09-05-2007, 02:08 AM
Sup guys, im tryin to figure out the best way to paint my hull. I took a hit in a race
and have resin the inside with cloth around the hole, and marine bondo the outside, and sand it down to finish.
Now i cant find the same color, which is the orange one, so am forced to sand the entire hull and paint an available color localy. my delema is,
is there some kind of gellcoat paint of some sort or,
do i have to sand off the gellcoat off the stock hull,
or will the new paint stick well to the hull with some rough sanding,
or can i find the matching pait,
what should i do? :confused1:
My aim is to use this hull in races, and if it gets beat up, i dont mind doing glassing, sanding, and painting the fixed area. I just want it to look decent everytime i fix the crashes, without re-doing the whole hull everytime.
Thanks guys. ALOHA
Tunda
09-05-2007, 04:53 AM
J iwould repaint the whole hull since youre all most there just sand the rest of the hull and buy some paint that i told you and spray um:doh: call me tomorow..............
whiplash
09-05-2007, 05:37 AM
alright, alright I'll do it like you said...........shoots
kck741
09-05-2007, 07:25 PM
What kind of paint are you going to use
whiplash
09-06-2007, 12:58 AM
kck, im not sure what to use, got any idea? today i have bondo the side and sanded down the entire hull, rough to lite, than to 600 wet sand. than painted with primer. going to let dry over night and decide what paint to use. heres some pics :tongue_smilie:
kck741
09-06-2007, 09:27 AM
From what I see that primer coat looks good(how many coats are there)!
If you want to use spray paint use Krylon Fusion,but if you want to use something different I would use ASE(All Surface Enamel)Its an acrylic latex paint super flexible and you can make just about any color you want,the only down side to it is you have to use a spay gun!!f you want to use that product I could send you a data sheet,well now that I think about it i can send you a data sheet on the krylon fusion paint too!!
Look at the sig I work for Sherwin-Williams!Ill be more than happy to help you with finding the right paint for the SV send me a p.m:buttrock:
whiplash
09-06-2007, 08:27 PM
I have 2 coats of primer, i just started with the wet sand, dried, and the first coatof the first stage of that dupli-color laquer camillion (spelling) paint blue/red
Im also taking pics as i go, so, hope it comes out good. posting later today.
kck741
09-06-2007, 08:59 PM
That sounds like it will work out well
whiplash
09-06-2007, 09:19 PM
here are some of the first and second stage:tongue_smilie:
whiplash
09-07-2007, 12:38 AM
almost finished.......
Tunda
09-07-2007, 03:52 AM
Wow J it came out really nice awsome job............... you better watch out for kimo..........
whiplash
09-07-2007, 06:49 AM
Tunda,
Did you Guys pickup the hull for Kimo? I installed the spectrum RX today in the llumar and epoxied the wood under the gas tank, It was starting to get soggy.
Also, installed a fuel filter and new futaba servo for the throttle. Next run I am going to experiment with lead weights to minimize blow over coming out of the turns. Shoots
Tunda
09-08-2007, 04:48 AM
sounds good kimo wanted to run sat or sun.........
mr.mauian
09-08-2007, 04:00 PM
wo cuz nice damage...lol. I know them guys like the inside corner.....dirty buggahz...j/k. West Marine sell a clear gel coat spray and even Fiberglass Hawaii. They get some allright colors too. See ya next week..........
mr.mauian
09-08-2007, 04:02 PM
Ohno thats not the mirage paint is it ? My boats are or look the same color.....
mr.mauian
09-08-2007, 04:04 PM
ahh nice color mine is purple green.
whiplash
09-08-2007, 06:37 PM
sup duane, is that you? got u on my buddy list too. kimo is 7sec57vette,
Kale is tunda. yeah im going to check that out at west marine. I like air brush something then go over with some gel coat. heres som pics with the canopy finished. ready for the hardware...:drool:
Team A-Hull
09-08-2007, 10:56 PM
Do you spay a clear coat then go over it with a gel coat? Or just primer, paint and gel coat?
whiplash
09-08-2007, 11:42 PM
No gel coat on this boat yet..... just a black base coat, the red/blue mid coat then the clear coat. 3coats of the first and second stage, and 4-5 of the clear, alittle more where i put the seal tape though. I want to airbrush something then try gelcoat over that to make it hard. I hear it comes in a spray can...amazing.
what you got?
Team A-Hull
09-09-2007, 01:19 AM
The boat i'm working on is an sv 27 like yours. I wanted to make it look mean and a little different. I think i'm going with blood red and black and the deck a firey skull made of vinyl. Just wanted to know the process especially the gel coat. Where do you get the gel coat in a can?
I wanted to try a sprayer but i need figure out that whole set up.
Krylon fusion was reccomended earlier but not to many colors to choose from.
Boat looks good!
whiplash
09-09-2007, 01:46 AM
Krylon fusion is better for plastic, it should work good on plastic hulls like those cheap NQD hulls. I heard it dont work so good on fiberglass hulls or on top of paints like enamel, laquer or gelcoat. tried it over laquer primer and after drieing
I could peel it off with my fingernail.
The gel coat in a can, a friend told me about that, at the local marine shop. still haven't tryed it yet. the blood red sounds good that was my first choice. post the progress here if you like.ALOHA
whiplash
09-09-2007, 01:53 AM
another guy told me he uses a clear resin with catalyst and applies it with his
airbrush set up. that sound preety good too.
Team A-Hull
09-09-2007, 03:14 AM
Thanks Wiplash!
The right color is hard to find...
I want to get the boat broke in and i'll start to paint after a few mods are done and so on. I would like to find something like exhaust, or something to make it look beefy and tuff! Will see were the process takes me and what i actually end up doing.
I defenetly let you know!
whiplash
09-09-2007, 07:12 PM
here's the finish product.....all plain aluminum hardware, hand made turn fin,
ready for the water :drool:
whiplash
09-09-2007, 07:14 PM
heres more.......
Team A-Hull
09-09-2007, 07:26 PM
Looks good wiplash!
whiplash
09-09-2007, 07:30 PM
from new, to crash, to pimpin'......:buttrock: Kimo, Kale, and duane,..........I'll just take the outside corner O.K.?
Team A-Hull
09-09-2007, 07:40 PM
Ouch i never really looked at the first pic! You saved that boat! But isn't it fun bringing something back to life?!?!
Tunda
09-09-2007, 11:25 PM
I think i might give you a little bump so we can breakin that new paint job.......Nah
......just kidding you did a nice job!!!!!!!!!!!!!!!!!!!!!!
7SEC57VETTE
09-10-2007, 12:32 AM
:laugh: HAWAIIAN! JUS RUN UM LAA DAT! FLOORBOARD!!!!!!!!!! YEEEHA!
7SEC57VETTE
09-10-2007, 12:44 AM
SERIOUS BRADDA I HAVE CASE OF SPRAY ENAMEL IN "BOBCAT ORANGE" UR WELCOME TO HAVE SU IF U WANNA TRY IT......LET ME KNOW 234-KIMO!:biggrin:
whiplash
09-10-2007, 04:22 AM
Thanks bradas for the inputs, and helpin me gettin into this hobby, I look forward to days at the pond.......I just hope it performs as good, on Sunday lol, Thanks to my Brada Kale, for frontin me the boat, got me hooked, I dont know if thats a good thing, nah, nah, A hui hou!!
Mich. Maniac
09-10-2007, 11:07 PM
why do you have dual pickups on that. one for motor, one for esc?
hookedup
09-10-2007, 11:48 PM
just look out for the "WHITE KNIGHT"!!!:sneaky2:
whiplash
09-11-2007, 01:41 AM
rodger that Mich. Maniac,
Ive thought about using the OSE jackets or the stock one, but the salt water would start to eat at the paint on the motor than you may have leaks, any experiance on that?:D
whiplash
09-11-2007, 01:44 AM
:laugh: lol, whats up jimmy? you comin out Sunday?
7SEC57VETTE
09-11-2007, 03:47 AM
IT'S LOOKIN GOOOOOOOOOD! AURYTE!
:buttrock:
7SEC57VETTE
09-11-2007, 03:58 AM
DON'T LOOK BACK! CASPERS STILL IN THE GAME! YEEHEEEEE!
:laugh:
7SEC57VETTE
09-11-2007, 04:04 AM
U GUYS GOTTA SEE MY NEWLY "REINFORCED HULL" MODIFICATIONS!!!!!!!! (2" WIDE STRIP OF CLOTH GLASSED RIGHT AROUND THE OUTER SIDE OF HULL) :laugh: :laugh: LOOKS KINDA ROUGH.....BUT OH WELL! MAYBE ILL BLOCK SAND IT??????????????:laugh: :laugh:
whiplash
09-11-2007, 05:04 AM
why you neva put em on da inside Kimo? lol
whiplash
09-11-2007, 05:07 AM
Braddahs post your boats man lets see em:drool:
hookedup
09-15-2007, 02:09 PM
hmm... tomorrow is sunday..."cough...cough...cough...:sneaky2:
whiplash
09-16-2007, 02:53 AM
:drool: :drool: Just Bring It :drool: :drool:
Team A-Hull
09-17-2007, 08:39 AM
How is the boat running now that you got it back together?
7SEC57VETTE
09-17-2007, 08:10 PM
Not Sure If U Got The Right Guy But It Ran Well Enough To Put A Ear To Ear Grin On My Face!!!!!!!!!!!!
whiplash
09-17-2007, 11:19 PM
Kimo I think he was talking to me...It ran very well, all I need is lipos then set up little beter, should be nice. Kimo did very well to yeah brada?
whiplash
09-17-2007, 11:22 PM
I geuss JIMMY was sick SUN. by the sound of his cough......cough.....cough.
He never showed, hmmmm. lol
hookedup
09-18-2007, 12:10 AM
whats up boys!! so i guess you guys have had enough practice... spankings will be given in 2 weeks:w00t:
jay, nevermind about the them running lipo's, i will be running my crappy 3800's!! "its all in the set-up grasshopper" i will show you some NIMH tricks bum-bye.
oh and i will bring a neckbrace...just in case:lol:
whiplash
09-19-2007, 01:04 AM
muayyyyhaahaaahaa.....
mr.mauian
09-19-2007, 09:19 PM
you need to find a marine and hardware type of store, someplace that sell marine equipment. The gel coat clear in a can is no longer available, I found that out 1 week after I saw it. Something about the enviroment or the E.P.A.. Gel coat I beleive comes in a quart and larger but you need a spray gun, never tried brushing gel coat. Some stores in our neighborhood are..... West Marine, Fiberglass Hawaii, they both have gel coat paints in diff. colors.
whiplash
09-20-2007, 02:30 AM
see if we can spray it on with airbrush
badag98
03-05-2010, 04:50 PM
Just wondering what type of primer did you use, I crashed the nose of my SV and have it all patched up and sanded in areas of repair and was going to primer the boat but was not sure which primer to use? Any thoughts?
:help:
