View Full Version : Little unstable on right turns
BHChieftain
01-16-2010, 01:57 PM
Hi,
Did a couple of runs with stock setup, plus X642 prop (picture shows a 440/3, but I swapped it out). I'm using the modified trim tabs (dogears) and fins. Boat is still a little unstable on right turns. We are probably going 1/4 to 1/2 throttle on the right turns, but if we start to power out of the corner she'll bounce around quite a bit and we need to back off. Left turns seem smoother.
Check out the tab/fin alignment and let me know if these look ok, or should I try bending the fins even further out (this set of fins/tabs actually came from Jesse's old boat, that way I can return to stock setup easily on this boat).
Thanks,
-Chief
PS, X642 is much better than 440/3 on this boat. No cavitation problems when pulling up to plane.
lectriglide
01-16-2010, 08:57 PM
Try bending the fins out more. Here is a pic of Darin's boat with the handling suggestions that you or previous owners have done. The turn fins look bent out more that yours. If I remember, Jesse also modified it to where the batteries could go all the way back to the transom, so you might try moving the batteries toward the front a little at a time till you find the right COG. Moving them forward will make it ride a little "wetter" and increase the stability. Mine turns at full throttle but too quick a turn will make it hook.
BHChieftain
01-16-2010, 09:03 PM
I'll give that a try. But I'm wondering if maybe vertical fins combined with the dogears on the trim tabs might work-- I know on deep vees the fins should be // to the keel, but the bottom of the fastech is actually flat-- which makes me wonder it that's the reason it comes stock vertical...
Anyway, I'll experiment with different configs and report back.
-Chief
lectriglide
01-16-2010, 09:10 PM
Read this thread first. According to Darin (Pro Boat Race Team) leaving them stock won't handle worth a darn.
http://forums.offshoreelectrics.com/showthread.php?t=8080
LiPo Power
01-16-2010, 09:21 PM
Hi,
Thanks,
-Chief
Generally this boat will be little wigily on right turns. It did this to me also. She is great in left turns but I know I know..... Check on Jesses mods to fix this but stock will just be like that .....
BHChieftain
01-23-2010, 04:58 PM
Bent the stabilizer fins out a little more to be perpendicular to the keel. What a difference-- she is running fantastic now. Here's a pic of the fin setup, and a video of our run today.
http://www.youtube.com/watch?v=5yuSD4ARCw4
-Chief
never2much
01-23-2010, 09:14 PM
I had the same problem with mine. I loosened the out drive and adjusted it up as far as it would go. I was going to buy new turn fins, but seing yours I will try bending mine as well. Great idea!!!!!
BHChieftain
01-23-2010, 10:18 PM
Credit goes to Darin! Note, try to get them perpendicular to the keel. On mine, you'll notice the left fin is bent out just a tad too much-- the right one is spot on.
-Chief
lectriglide
01-24-2010, 12:40 AM
Chief
Looking good. If you really want some fun, try a couple 2s lipos. It'll make you :banana::banana:
