View Full Version : New version EagleTree Gps now 1/2 cost!
01-15-2010, 03:37 PM
The new and improved EagleTree Gps V4 is now 1/2 the cost of what it used to retail for!!!!
$64.99
http://www.offshoreelectrics.com/proddetail.php?prod=etr-GPS-v4
vvviivvv
01-15-2010, 04:42 PM
can they be mounted on the hull? as in taped to the deck ? are they semi waterproof ?
01-15-2010, 04:44 PM
I havent tried one yet. Its just to cold around her.
No, you would need to use a corrosion x or similar.
vvviivvv
01-15-2010, 04:53 PM
There is the expander version which is made to be mounted outside the cf was just thinking if i go mental with the hatch tape on it on top of the deck it'd be fine will probs order one anyway 2 moro
doesn't work with the v4 tho
tharmer
01-16-2010, 12:26 PM
Do the old v3 sensors work with it? E.g., the GPS?
-t
01-16-2010, 02:17 PM
-t
The actual logger has not changed. Just the gps module has been updated.
vvviivvv
01-16-2010, 02:32 PM
So, does any 1 have any concerns before I order 1? Will they be ok mounted inside cf or ontop of the deck with hatch tape covering?
01-16-2010, 04:27 PM
I would suggest waiting a while before buying one if you want to use it in a carbon hull.
vvviivvv
01-16-2010, 04:29 PM
i have other boats i can use it in so not the end of the world just ordered one + a logger and some temp stuff
have small plastic bag which can be sealed and stuck to the hatch for the cf hull
01-16-2010, 04:46 PM
I see the order. Thanks.
old guy
01-16-2010, 09:04 PM
Jut put it in a balloon. You can get one with a wide opening. I use condoms becouse I get them for free:banana: Then just tape it to the boat. use a rubber band on the end to seal it. hope this helps ya
befu
01-16-2010, 10:45 PM
I hope they are new and non lubed!:doh:
Actually, this new version and price is fantastic! i was planning on buying one this spring, but without the gps. For sport running, couldn't bring myself to spend the coin. But now, yeah, I can do that. I should order on in March, so about the first day of march you should sell out for the next several months!
brian
