View Full Version : WTB minicat or other 20mm motor
Chuck E Cheese
01-14-2010, 05:11 PM
i am looking for a minicatracing motor with coupler. i need the 3800 or 4200kv because i will be running on 2s in a micro rigger.
let me know what you have and price
rhinopole
01-15-2010, 10:38 AM
Not sure if this helps, but I have a new FSD 2040 3600kv motor and a new Tenshock 20mm motor from a Tenshock mini Y rigger. I am not sure of the KV on the Tenshock motor. The color of the top part on the Tenshock is black if that is any indication of the KV, I am not sure. The Tenshock also has the black water cooling jacket on it. Both motors have a 2.3mm shaft. Let me know if you are interested.......
sailr
01-15-2010, 01:25 PM
The Tenshock is 3200KV
bigwaveohs
01-15-2010, 02:47 PM
PM sent
Meniscus
01-15-2010, 04:38 PM
I have an Ammo 20-40-3500, never been opened which I purchased a while ago for a micro.
SPECS: Motor Diameter: .787" (20mm)
Motor Length: 1.57" (40mm)
Shaft Diameter: .079" (2mm)
Shaft Length: .413" (10.5mm)
kV Rating: 3500 rpm/V
Weight: 2.3oz (65g)
Input Voltage: 7.4-11.1V
Max. Constant Current: 12A
Max. Surge Current: 25A
Max. Constant Watts: 133W
No Load Current: 1A
Up to 89% efficient as stated by manufacturer.
I would think you could prop up, as long as you have a good battery that can handle it. The only question is whether or not the wires will handle the load.
Chuck E Cheese
01-15-2010, 05:01 PM
thanks but no thanks, those are all too low kv for 2s.
pm returned
BakedMopar
01-24-2010, 06:04 PM
How much for the tenshock motor? Prices for each would be nice. My buddy is looking for a replacement. Let me know
ray schrauwen
01-24-2010, 07:50 PM
I have an ARC 130 motor NEW, never run.
20 x 34 -4 poles, 4600 kv. These motors can be pushed pretty hard.
Let me know....
http://www.lightflightrc.com/
rhinopole
01-24-2010, 10:23 PM
PM sent.....
BakedMopar
01-28-2010, 08:26 PM
PM sent.....
Didi this get shipped out? Do you have tracking number.
rhinopole
01-28-2010, 10:02 PM
It went out USPS Priority today from L.A.. Lance should get it by early next week.....
