View Full Version : Cativation
BHChieftain
01-10-2010, 01:26 PM
Hi,
I upgraded the (broken) stock prop with a 440/3, sharpened and balanced. I like the speed the boat gets with it, but it does cavitate a little before it gets on plane. I'm a little worried the RPM limiter will kick in at some point, as my son will take the turns pretty slow which drops it out of plane frequently.
Do you think adjusting the shaft angle would make any difference, or should I just move to X642?
-Chief
Sorry about the thread misspelling-- I can't seem to edit it (moderator, help?)
LiPo Power
01-10-2010, 04:14 PM
I had X642 on my sold Formula and it was great so yes, try that prop.
egneg
01-10-2010, 04:33 PM
If you could lower the strut a bit (1/16 - 1/8) keeping the angle the same it may help as well.
LiPo Power
01-10-2010, 04:39 PM
...any chance for pictures of your set up from the back and side?
BHChieftain
01-10-2010, 05:29 PM
Here's the setup,
-Chief
Jesse J
01-10-2010, 06:41 PM
Does the one I sold you (formerly Robert's) happen to cavitate on your three blade prop? it has a much more adjustable strut... The stock strut is miserably limited in its adjustments. Personally, I would probably just use the x642 which had NO cavitation problems.
BHChieftain
01-10-2010, 10:31 PM
I'll swap the props between the 2 boats and muck around with the adjustments on Robert's since there are more degrees of freedom on that one...
-Chief
LiPo Power
01-11-2010, 12:04 PM
... Just like Jesse said, X642 will have no cavitation problems no matter what the angle is. If I remember properly I had the same problem trying Ul-1 prop and decided to swich back to X642. That prop made my Formula even more stable with great speed of arround 37MPH on stock setup and still great controll of the boat....
Cheers
Robert
BHChieftain
01-16-2010, 02:37 PM
Cheers
Robert
Hi,
Just finished 2 runs today with the X642. It's much better than the 440/3, no cavitation at all...
Thanks,
-Chief
LiPo Power
01-16-2010, 09:17 PM
Hi,
Thanks,
-Chief
Way to go!!!!
