View Full Version : New Turnigy ESC
lectriglide
01-09-2010, 05:21 PM
Anyone have one of these yet?
http://www.hobbyking.com/hobbycity/store/uh_viewItem.asp?idProduct=10626&Product_Name=Turnigy_AquaStar_120A_Water_Cooled_ES C
Says waterproof PCB and programmable by PC via USB. :thumbup1:
egneg
01-09-2010, 05:45 PM
This is the first I have seen it ... but I did notice that the Shrink rap will have to be cut as it covered the water cooling.
detox
01-09-2010, 06:02 PM
NICE...looks like 4 caps installed...maybe just two. To be programed by a computor it must come with software and maybe USB cable.
detox
01-09-2010, 06:05 PM
I see that USB link is optional:
http://www.hobbyking.com/hobbycity/store/HobbyKing_New_RC_Products.asp?orderBy=recently
sailr
01-09-2010, 10:34 PM
A company dumb enough to cover up the water fittings with the shrink wrap would not make me comfortable using their stuff!
detox
01-09-2010, 11:30 PM
I've had to cut back the shrink wrap on all of my Castle Hydra esc's. Although not completely covered by shrink wrap, not enough of the aluminum water tube was exposed.
properchopper
01-09-2010, 11:43 PM
I pointed that out to Patrick at the CC booth at RCX some time ago. He said he'd address it. :roflol:
alvinsmith75
01-09-2010, 11:46 PM
^^^^^^^^^^^^Ha ha I was thinking the same thing. Not to mention, try installing lines on the 240 esc's.
ksm2001
01-10-2010, 12:41 AM
Price is great, nice to see more esc's coming out and prices going down. BTW Ditto on the CC shrink wrap.
Ken
Chilli
01-10-2010, 01:13 AM
I've had to trim back the Etti 150's shrink wrap also.
Rumdog
01-10-2010, 02:10 AM
uuummmmm, the ETTI 150 has absolutely no shrinkwrap.
Jeepers
01-10-2010, 02:20 AM
Ditto!!!
Chilli
01-10-2010, 08:20 AM
You know what Ryan, your absolutely right! I shrink wrapped them myself so I could velcro it down. :doh:
egneg
01-10-2010, 08:29 AM
This new ESC looks a lot like the Swordfish that Steven posted.
http://forums.offshoreelectrics.com/showthread.php?t=11389
motoxbob11
01-10-2010, 12:00 PM
I just got a new 240 also and neither size tubing that I got from OSE seems to be able to fit. The tubes are too close together. What is the secret?
Jeff Wohlt
01-10-2010, 03:20 PM
And......back to this post. At least a program module! the shrinkwrap???...I think I can handle that mod.
alvinsmith75
01-10-2010, 05:14 PM
I usually use saliva lube and slide both lines on at the same time. You can also use a small screwdriver or allen wrench and slide it in the tube and carefully pry them apart.
bustitup
01-10-2010, 05:56 PM
its very easy but be very carefull
slid something into the tubes (the same size as the inside diameter of the tube) and very carefully bend it to the side just slightley
if you were to mark them 1 2 3 4
bend 1 and 2 to the left and 3 and 4 to the right.....you dont need much bned to be able to slide the fuel tubing on so bend very little its easy
bustitup
01-10-2010, 06:13 PM
that my freinds looks like they added water cooling and upgraded the old hextronic esc...it also programs with a usb thingy and was a very very good esc
http://www.hobbyking.com/hobbycity/store/uh_viewItem.asp?idProduct=4316&Product_Name=hexTronik_PRO_120A_BESC_w/_PC_Programmability
For the watercooling tubing I used silicone lube spray on both the pipes and the tubing, worked a treat, was really struggling with them prior to that.
sundog
01-10-2010, 09:02 PM
I'm not too crazy about having just one water tube along one side - like the Etti 150A non-opto (w/bec). Just doesn't seem like it will be as efficient as two - how many cents would another tube have cost them? It cost Etti another repair when mine fried a while back. Methinks they should go back to two tubes like on their opto model. :doh:
