View Full Version : One sweet ride
bustitup
01-07-2010, 05:20 PM
http://cgi.ebay.com/Custom-Electric-Baja-5T-1-5-Truck-RTR-2-4GHZ-HPI-Comp_W0QQitemZ140367899105QQcmdZViewItemQQptZRadio _Control_Parts_Accessories?hash=item20ae9429e1
Brushless55
01-08-2010, 01:10 AM
wow, if he sells it for that, I'm building 3 and selling them!
ozzie-crawl
01-08-2010, 02:19 AM
he has taken out a 23cc motor and put in a fiegao 580l :confused2:
for that sort of $$$$ i would want at least a neu 1900zr
As nice as it looks that 150A ESC is not enough for it. I'd want a bigger motor too.
wakeboardfusion
01-10-2010, 02:45 PM
Why would someone do all that work and put el chepo esc in there?
The ESC is actually pretty good, I have one in my Speed Car and it is very similar to the stuff Speed Passion sell. I'd want at least 200A in a 1/5 truck.
Brushless55
01-10-2010, 03:41 PM
not that I'm trying to sell this over priced electric buggy.
that esc I think will take 1000 Amp spikes? :confused2:
AFAIK a surge is usually only 75% of the cont. so the 1000A won't be used as the ESC would blow prior to that.
Diegoboy
01-10-2010, 05:24 PM
SPECIFICATION
•Continues Current: 150A
•Max Current: 1080A
•Input Power: 2-6s li-poly battery pack or 6-18s Ni-MH battery pack
•BEC: 5.75V/3A (Switch mode built-in BEC)
•Resistance: 0.0002 Ohm
•Motor Supported: Sensorless and sensored brushless motors
•Suitable Brushless Motor: 3.5T and > 3.5T
•Suitable Car: 1/5, 1/8 on-road or off-road cars / trucks for competitive race.
•Weight: 150g
•Dimensions: 68 x 55 x 45mm
Pulled from Here (http://www.rc-fever.com/hobbywing-ezrun-150a-sd-brushless-esc-for-15-18-car-p-7454.html).
Brushless55
01-10-2010, 07:27 PM
you got the goods Diegoboy :thumbup1:
maybe the cont. should be rated higher?
We shall see, I'm using one for speed runs in a 1/10 touring car. Its massive! Only on a 540 3.5T now but will be going with a 1/8 motor and 6S in the future so if it can handle that easily maybe.
Brushless55
01-10-2010, 08:17 PM
oh man, not an issue for that car..
I've seen these escs in 1/8th scale MT on 6s without issues
ozzie-crawl
01-11-2010, 01:17 AM
if a neu 1900zr (direct zenoah replacment) was used you would probably get away with a 120a hv esc
This truck is way way bigger than a 1/8 MT. Far heavier too.
Brushless55
01-11-2010, 10:55 PM
Awesome, that was just my point to your post.. :thumbup1:
Brushless55
01-11-2010, 10:58 PM
Like these?
http://www.castlecreations.com/products/neumotors/nm1900.html
Ah I get what you meant now! Thought you were talking about the 1/5 truck not my 1/10 TC :doh: Yeah I shouldn't have any issues with it, although when you are so overgeared for speed I still need to keep an eye on it.
Brushless55
01-12-2010, 11:42 AM
:hug1:
http://i36.tinypic.com/2hyhq92.png
http://i37.tinypic.com/vsew78.png
:p
Brushless55
01-12-2010, 12:17 PM
nice :thumbup1:
what speeds are you going for?
I've only used it once, it ran 53mph with 1/8 throttle! But the problem wasn't power, it was grip. I was using old foams from an old car so there was no grip at all. I've now got some better foams. Still snow on the roads here so I haven't had a chance to test it yet.
I'm hoping to break 100mph. It has the potential to do so. With the current motor I think that 90mph or so is the max on 2S lipo. Once I can get it running at speeds like that consistantly I'll go for a bigger motor and more lipos.
