View Full Version : need esc cooling help epoxy or what
Jcarlton
04-10-2007, 12:15 PM
how would i go about water cooling my esc ? ive got some aluminum tubeing but what epoxy should i use or should i use epoxy? the esc is a brushless m tronics genesis with a 3000k motor its for a e -maxx but i want to put it in a boat!! if you want check out the genesis truck combo @ mtronics.com . need some pics of someones jobs would be great!!
SJFE
04-10-2007, 12:25 PM
This is what you are looking for. I have bought from this guy. Fash shipping...Good price. http://cgi.ebay.com/Arctic-Silver-Premium-Thermal-Adhesive-Epoxy-NEW_W0QQitemZ320100874719QQihZ011QQcategoryZ46322Q QssPageNameZWDVWQQrdZ1QQcmdZViewItem
SJFE
04-10-2007, 12:26 PM
Couple things....It's permanent..so be sure you dont want to take what ever it is you bond apart. If your unsure of that...He sels thermal tape also.
SJFE
04-10-2007, 12:29 PM
Here is the tape.
http://cgi.ebay.com/THERMAL-TAPE-25-x-25mm-Double-Sided-Adhesive-FREE-SHIP_W0QQitemZ320101687215QQihZ011QQcategoryZ46322 QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Jcarlton
04-10-2007, 01:08 PM
do you have any pics ? or i guess i could put connectors on it if i have to remove the wires
Jcarlton
04-10-2007, 01:29 PM
tring to waterproof it so the epoxy will work best? would you go to the m tronics site and verify?
SJFE
04-10-2007, 01:49 PM
I can see you are kind of new @ this so let me explain how the forum can best work for you;) . Step 1. You collect all the information you can about the item you are looking for help with. Step 2. Take a couple of pictures. Step 3 You present us with ALL the data and pics. Then we offer our opinions on how you can best get your project done right. I don't mind offering advice. I am how ever to busy to go check out sites for information that should have been collect befor the question was asked. So in short go grab the pictures and the esc's exact specs, Post them and we would be happy to offer up solutions.:)
Rex R
04-10-2007, 06:23 PM
Observation/Comment
castle creations uses heat shrink material to hold things together.
SJFE
04-10-2007, 06:37 PM
Observation of Comment.
I noticed that. Seemed kinda odd they didnt make an effort to insulate the plates from the fetts or boards./
ED66677
04-30-2007, 11:18 AM
why don't you use a .25" thick piece of plexi (or any plastic) mill a U-shape path with your Dremel, not too deep but wide, glue two fittings at each end of the path and stick everything with silicon on a 1/8 aluminium or copper sheet?
