View Full Version : 24" riger weight question
ezhitz
12-12-2009, 01:07 PM
I build a rigger 24' oal and weights 2.46 lbs or 1.117kg thats encluding 2s 5000mah lipo. my question is i know you don't want it too light but what would be getting to heavy?the motor is a 7s feigao. thanks
Simon.O.
12-12-2009, 04:33 PM
I have a rigger with a 22" tub and is 26" overall.
I don't have a weight on it but the 5000mAh pack and a 7S is what I run too.
A 100A mystery esc and then a 5cell aaa rx pack and 9g servo and small rx makes up the rest of the weight.
The hull is mostly balsa so is fairly light.
On choppy water I shoot a couple of 9v square cells in the front to add a bit of weight to hold it on the water.
Go with what you have and I am sure that you will be fine. Do you know where your Cg is or will be ?
ezhitz
12-12-2009, 07:56 PM
Simon thanks for the reply i thought you had one running thr same motor.
Mines balsa and 1/32 ply its a copy of my jae 12g. The water is frozen here now until spring
so i can't try it. Balances around the turn fin no rx pack in.I will try post a picture of it.
ezhitz
12-12-2009, 08:22 PM
heres a couple of pictures before i finnished it.The sides are 1/8 balsa with mahogany vaneer and the rest will be painted orange with a white bottom.
