View Full Version : Need Help Mini Hydro
BakedMopar
12-04-2009, 10:43 PM
Hello I have recently acquired Diegoboys Mini Hydro and need some help tuning this thing. I have no hydro experience so go easy. I got the boat to run a straight line well it just wont turn. You have to really creep through the corners. It seems to be stuffing the left side in the water at speed in the turns. It currently has no turn fin. Need some advise on placement, size etc on the fin.
Heres the current setup.
Total lenth is 17.5"
C.O.G. is at 2 7/8" behind the rear of the front sponson.
Here are some pictures. The last ones are where I think the turn fin should be. Due to the size of the hull would it be okay to mount on the hull and not the sponson? Its tight in there and the ride pad is way in. Should I space it out or should I run it as close to the hull if it's okay to mount it there?
Thanks George
RandyatBBY
12-04-2009, 10:58 PM
he turn fin should not need to be more than 3/4 inch below the ride pad on that size of the boat. It will make the boat turn. The CG should be in the center of the turn fin. I put the CG about 1.25 inches behind the rear of the ride pad. If the CG can not be moved then move the turn fin back.
BakedMopar
12-04-2009, 11:00 PM
Yes the battery is all the way up front. Could I mount the fin to the hull instead of the sponson?
RandyatBBY
12-04-2009, 11:07 PM
No need I quote you said "C.O.G. is at 2 7/8" behind the rear of the front sponson"
So you put the turn fin in the middle of the COG.
BakedMopar
12-04-2009, 11:19 PM
Okay here is a picture of the middle of the turn fin would be at COG.
RandyatBBY
12-04-2009, 11:38 PM
as far as placement looks good but no more than 3/4 below the bottom of the ride pad. Like in the picture below.
http://img687.imageshack.us/img687/1355/img2267a.jpg (http://img687.imageshack.us/i/img2267a.jpg/)
BakedMopar
12-04-2009, 11:50 PM
Okay cool. My only concern is mounting a bracket to the sponson. It seems really thin and Is a pain in the ass to reach in there. That is why I ask if it okay to mount from the side of the hull.
BakedMopar
12-05-2009, 06:45 PM
So I went out to run it again today. I tried a V935 that was cut down to 32mm with this prop it was very hard to get on plane. When it did it scooted though. What kind of adjustments do I have to make to get this prop up on plane easier.
Jesse J
12-05-2009, 08:12 PM
maybe a touch deeper strut.
BakedMopar
12-05-2009, 08:23 PM
Leave the angle the same? I am trying to convert some short video will post them up later.
JimClark
12-05-2009, 09:02 PM
show pictures of the inside setup.
BakedMopar
12-05-2009, 09:31 PM
This is how the inside is setup. The speed control is in the Port side sponson and the reciever is on the starboard side. It was originally setup with the speed control on the starboard side but the torque roll was really bad.
BakedMopar
12-06-2009, 12:21 AM
Here is what I did for the turn fin mount. It look good to me. What do you thinnk? The fin will be trimmed at the last bend.
BakedMopar
12-06-2009, 01:34 AM
Here is a short video. It shows how it flips in the turns.
http://www.vimeo.com/8008927
JimClark
12-06-2009, 03:52 AM
hw much servo travel do you have set up plus you are taking a very tight turn
Jesse J
12-06-2009, 11:39 AM
How much hook on the fin you got? On these micros, I have noticed that it is a balance between torque roll and enough weight on the inside (starboard) to keep from flipping. It looked like something caught and flipped you over; thus need to see the angle of your turn fin - please post a pic of the underneath so we can see just what angle your turn fin is set.
BakedMopar
12-06-2009, 12:13 PM
In that video there was no turn fin. The rudder has about 30 degrees of throw.
Jesse J
12-06-2009, 12:22 PM
How many times has it flipped like that? and agree tight turns can do this to you. A turn fin will definitely help this, especially with some hook in it.
BakedMopar
12-06-2009, 01:15 PM
It flips a lot. Almost every other turn. I will try to get you some pics of the turn fin.
Rumdog
12-06-2009, 01:17 PM
Agreed, less rudder throw, longer sweeping turns and the turn fin is a must!!
JimClark
12-06-2009, 02:23 PM
Before I would mess with the turn fin I would add weight to the nose to drastically change the CG seems like the CG is way back too far
BakedMopar
12-06-2009, 02:26 PM
Here are some better shots of the fin mounted and trimmed. I turned down the rudder throw to about 20 degrees. I am going down to run it now I will get back and let you know how it did.
Thanks for the help guys!
BakedMopar
12-06-2009, 02:49 PM
I'll take some weight with me. Where should cog be?
RandyatBBY
12-06-2009, 02:50 PM
Have you ran it sence you put the fin on? I run that type of fin in that location with a little more curl to hold in the cornor, turn right only at full speed and let off power to turn left. Turn fin should be stright up and down.
RandyatBBY
12-06-2009, 02:52 PM
I'll take some weight with me. Where should cog be? \
If you put the CG foward you will need to move the turn fin foward.
BakedMopar
12-06-2009, 06:41 PM
Okay after a whole buch of swimming er testing, I think it runs much better. I had changed the layout of the electronics. I put the speed control back to the starboard side. I added 3 oz of weight to the port sponson and 2 1/2 oz in the middle. This was the last and best setup so far. It lost a some speed but was much more stable. I didn't have a camera person so I will try to get some later. I did not play with the fin at all with the exception of moving it's center in line with cog. All my testing today was with weight.
Thanks,
George
Jesse J
12-06-2009, 09:57 PM
I would think on one that size COG shouldn't be more than 1" back from trailing edge of sponson. Where is it now?
Did it flip any this time?
BakedMopar
12-06-2009, 11:56 PM
Okay here is a detailed breakdown of my testing. Plaese note that everything happens fast and my eyes aren't the best so this is what I observed.
1st run: Turn fin added only. Still flipped.
2nd run: Added 3oz. to starboard side. Same thing.
3rd run: Added 1 1/2oz plus the 3oz. from run #2. Seamed to bury the nose hard. I say that because I tend to see a lot of prop from the back.
4th run: Took everything out and remounted the electronics. Put the ESC on the starboard side and the receiver on the port side. I also took out all of the weights. Port side was really light and had bad sponson hop. Now it seemed that the fin was digging in and throwing the boat over.
5th run: Added 3oz weight to the port sponson. Calmed the hop down a little but turn much better. Flipped only once but I think it was from a cross wake.
6th run: Added 2 1/2 oz to the center (in the nose). Ran flat and turned even better. I did not flip it on this run. I still ease off the throttle a little but not much. I'd say about 85-90% on the throttle. This was the best it ever ran overall.
It lost a little speed with the fin but it's probably due to the extra drag. I did not play with any other settings other than those that are listed. The center of gravity is still way behind of what is recomended. When you say trailing edge is that where I am measuring from? This is a scale of the whole boat.
Thanks for all the help,
George
JimClark
12-07-2009, 12:54 AM
What motor and batteries?
BakedMopar
12-07-2009, 01:04 AM
Motor is a Feiigao 380 8L. Batteries are Turnigy 3s 2200 30c. Prop that was run today was a Octura X632.
Jesse J
12-07-2009, 09:23 AM
YEP. try adding the weight as FAR forward as possible. this way you add less and it is more effective. Think about what electronics you might be able to nudge forward. maybe tie a helium balloon to the rear....................
BakedMopar
12-07-2009, 10:19 AM
Everthing is as far forward as it possibly can. The sponsons have foam in the front 3/4 of it so the lead cannot be added to the tip where it would be best.
BakedMopar
12-09-2009, 01:24 AM
Went out to run it again today. I ran the same setup as last time with a few minor changes. Leveled out the strut and bent the turn fin a little more. She ran great. The starboard sponson seamed glued to the water but not running to wet. Still got a little port sponson hop in the corner if not at full throttle but at WOT its almost non-exsistant. I am still trying to get someone to take some video.
Thanks for all the help guys.:beerchug:
George
Jesse J
12-09-2009, 09:52 AM
Great description of run. VId would be nice to see the difference ... good job, sounds like you are having fun.
BakedMopar
12-12-2009, 12:58 AM
As promised I got some video. Runs a hell of a lot better but still not perfect. I proped down to a Y531 from the X632 for a little more run time and happier batteries.
http://www.vimeo.com/8132503
Thanks everyone on their input. :beerchug:
George
Jesse J
12-12-2009, 11:08 AM
Great work George, we can give advice, but you are the one who actually does the tuning. congrats! looks like you are ready to race ------------ go get em
BILL OXIDEAN
12-12-2009, 11:14 AM
She's movin' good!
boater76
02-03-2010, 01:24 PM
Who made that hull where would I be able to get it from?
BILL OXIDEAN
02-03-2010, 01:31 PM
Its a BBY racing micro hydro contact Randy at BBY here on the boards. i have one that does 70plus on 2s.
boater76
02-03-2010, 01:44 PM
Whats his user name?
boater76
02-03-2010, 01:46 PM
never mind found it
Diegoboy
02-03-2010, 02:06 PM
It's not a BBY hull. She used to be mine, and I got her from the HOTR guy, he doesn't offer them anymore.
boater76
02-03-2010, 02:12 PM
Ok. Thanks
Diegoboy
02-03-2010, 03:08 PM
I dug really hard for you, I can't find the bare hull, but I did find the boat, just labeled differently...
Here (http://twin-horse.com/product_info.php?products_id=188) <------
RandyatBBY
02-03-2010, 03:39 PM
He wanted the Bud hull not my Micro Hydro but after they see the Mini Zephyer run they will want one.
No guys there is no pictures, I am building a mold as I write this. No pictures untill records are broken by Will or me.
Diegoboy
02-03-2010, 03:43 PM
Randy,
You are going to keep me in poverty my friend! :bowdown:
(Do I pay the electric bill, or buy Randy's hydros???... Buy Randy's hydros!!)
RandyatBBY
02-03-2010, 03:50 PM
Randy,
Your Z-27
http://img5.imageshack.us/img5/8200/img2381r.jpg (http://img5.imageshack.us/i/img2381r.jpg/)
Diegoboy
02-03-2010, 03:59 PM
http://www.addemoticons.com/emoticon/animated/AddEmoticons04239.gif http://www.addemoticons.com/emoticon/animated/AddEmoticons04235.gif
If the Micro Z will be in carbon, Add me to the waiting list
RandyatBBY
02-03-2010, 04:12 PM
I allways do CF. The minni will not be out for quite a while. I have a lot of work to do and the weather is getting better in Cali.
http://img63.imageshack.us/img63/9575/img1513gh.jpg (http://img63.imageshack.us/i/img1513gh.jpg/)
Meniscus
02-03-2010, 04:14 PM
You know Diego, Randy may want some assistance updating his website and shopping cart to include all of his newer models. I think I know someone that could help with such a thing, someone who would take their time and has a great attention to detail.
Maybe you could still pay, let's say, a 1/10 of the electric bill :thumbup1:
=> I'm wondering if the work Randy is referring to is under a tarp in the background! :lol:
Diegoboy
02-03-2010, 04:24 PM
I would LOVE to update the user-friendliness of the site. Even put dimensions of all the models available too!
Sorry for jacking your thread BakedMopar
RandyatBBY
02-03-2010, 04:34 PM
That is my sons car a 1965 Impala 424 hp 350 bagged on dubs.
Sorry to Jack the thread too!
Dick Crowe does my site. I could have him do more, and will but it takes me sitting down and doing my part. I would rather work on.......
http://img202.imageshack.us/img202/3913/img2382z.jpg (http://img202.imageshack.us/i/img2382z.jpg/)
Meniscus
02-03-2010, 04:45 PM
My apologies BakedMopar. Do you still need help?
Randy, well it was worth a try. Maybe Diego could put together the simple stuff like, resizing photos, pricing write-ups (CF, FG, etc.), dimensions, etc. in preparation to go to Dick. Basically consolidating what you have on the forum. Anyway, it was a joke and a offer for assistance so you can keep creating the stuff!!! For heavens sakes, don't stop for website updates! That's not nearly as interesting. LOL
RandyatBBY
02-03-2010, 05:09 PM
I really would like to see a new front page I have had a idea in mind but know not how to do that stuff, or the time. I do appreciate the thought. It really needs to be worked on, get rid of things I do not do any more. Still it is work I need to do. Really I like to talk to people and this gives them a reason to Email or call me.
BakedMopar
02-03-2010, 05:35 PM
No prob. The hull was from Danny and it's to be a HOTR hull. I don't see it availible anymore. It's pretty and fun boat but not raceboat. It is currntly under reconstruction. Will be back soon and hopefully better. It does run pretty decent though after all. Trying to dial in my BBY mono with the help of Randy.
