BILL OXIDEAN
12-03-2009, 08:42 PM
Hey Gents,
I've been given permission to spill the beans about these new products..
I'm STOKED about being able to use 2s lipo rcvr packs and having even faster response!
Airtronics now has twice the response speed as the leading compettitor!
New Product Announcement!
Unbelievable progress on New Product from Sanwa!
1. The line of servos just exploded. As you recall, the line has had about
9 servos in it for the last year. We now have a EXPLOSION of new servos.
There are even more in development to truly help fill-in the line.
See the attached list. I just received the final specs on some of these
items today!
2. Super Response Servo and Receiver for the M11X
Sanwa has developed a new receiver for the M11X (in the same case as the
current M11X receiver) with a latency minimum rating of 2.5ms. That makes
it about twice as fast as the next fasted receiver in the industry.
The receiver, when matched with the M11X in the fastest mode, works at a
narrower pulse width. Thus reaction time and precision are improved over
any existing radio system. To take advantage of this higher performance,
Sanwa Created 4 new Super Response Servos. Two are coreless and 2 are
brushless!
The trick here is that the response time (from the time you put in an
input, as tiny an input as you can do to the time the servo actually
changes direction from where it was before) is massively increased. This
is "transit time" as the industry calls it, this is response.
See the attached draft of the press release for more info.
3. HI VOLTAGE.
Everyone is asking about running on 2 Li-Po's direct. Here's the facts as
they stand at the moment. ONLY the new Hi-Voltage 94910 and 94911 servo
are rated for 2 cell lipo direct. The other servos, in some cases, may
"work", but the motor life will be decreased. Most will simply "fry".
The new High Voltage servos are made for this type of current.
Both the Standard AND the new SSR receiver for the M11X are confirmed from
Sanwa to be compatible with 2 Cell Li-Po DIRECT!
4. SD-10G Owners Please Note:
First, the new SSR servos will not have the same performance they do on
the M11X SSR setup, but even in the SD-10G you will feel an improvement in
that "connected" feeling by using SSR servos.
Second, NO, the current 10ch receiver is NOT compatible with a 2 cell
Li-PO direct! Sanwa is working on a new Hi-Voltage solution.
Third, You now have a truly WIDE RANGE of servos to choose from that are
DIGITAL AND work with the High-Speed SD-10G 10Ch FHSS-3 receiver!
All of these new products will begin arriving early January and by end of
February we should have all of them in stock.
items today!
brushless!
3. HI VOLTAGE.
