View Full Version : What is a good prop for the mini rio ?
lucozader
11-18-2009, 12:29 PM
an octura
x 427
x 430
x432
thegreat1
11-19-2009, 02:42 PM
what is you setup?
lucozader
11-19-2009, 03:33 PM
brushless and lipo
thegreat1
11-20-2009, 05:28 PM
what is the size in mm of the motor and also what is the kv rating?
lucozader
11-22-2009, 06:51 AM
2600 KV brushless motor
Specification: Length: 40mm (exclude motor shaft)
Width: 20mm
Shaft size: 2.3mm
damfurst
12-06-2009, 07:11 PM
with that size motor I would think the x427 would be best. You could try the x430 but you would have the check the motor temp & esc to make sure you don't burn it up. Also, that size motor won't fit in the motor mounts on the mini rio, but you might be able to shim it someway. It definitly would need to be water cooled too.
Jesse J
05-02-2010, 09:46 PM
I just ran mine today with a 3000KV outrunner on 2S with a 432 and it rocked. motor came in at 55deg F...
